Automatic shifting into ?3rd? revs..
Old Jan 9, 2005
Karumba's Avatar
Boredom causes changes ;)
I've noticed a problem on my car within the past couple of weeks and I'm starting to wonder if it is a transmission/gear problem or something else.
The problem occurs when the car tries to put itself into 3rd gear (or what I believe is 3rd gear). At around 60km/h (roughly 40mph) when leaving the last gear the car tends to lag/stall and let the revs go a bit then catches again as it finally shifts. The revs tend to climb about 2000 (3k to 5k) usually before it changes - yes foot is still pressing the gas (usually not that hard).
My question arises is the fact that one friend believes it might be the crank shaft pulley. I know I am out of any sort of warranty period so I don't want to do needless repairs/inspections if its not necessary. The transmission fluid was changed around 25k kms ago (approx. 16k miles) so don't know if it needs changing already .. Anyways any help would be appreciated.
Old Jan 10, 2005
flotsamm's Avatar
Could be as simple as being low on tranny fluid, becareful when checking it and make sure you do it properly. Overfilling or underfilling is bad. Or, it could be worse like your clutch packs or torque converter are bad. Doubt it would be crankshaft pulley, thats not anywhere near the tranny. All the crankshaft pulley does does is spin the accessories..
Old Jan 10, 2005
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Do the cheapest repair first. Change your tranny fluid and see if problem is solved. I changed my tranny fluid every 15k and boy...what a difference it makes when switching gears. And remember to use Honda transmission fluid.
Old Jan 10, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
YES!
Old Feb 5, 2005
cargeek68's Avatar
From: Manila, Philippines - "The Pearl of the Orient"
cargeek68 is an unknown quantity at this point
so, is your car already fixed? i've been experiencing the same think lately on my 01 ex
Old Feb 5, 2005
My car bogs when after switching to third unless I have it on d3. Have you tried accelerating fast through the gears to see if it still does it?
JetsterDajet
Aug 15, 2015 08:07 AM
hunda91
Aug 12, 2015 03:04 PM
j-chest
Aug 11, 2015 02:26 PM
estes53
Jul 20, 2015 10:43 PM
Jul 12, 2015 11:54 AM
