Tranny/Clutch Problem
Old Dec 27, 2004
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I have a 2001 5 speed and yesterday, on the way to work, I was approaching a stop light and I put the clutch in and pulled the car out of gear so I could downshift. Well, when I tried downshift the car would not go into ANY gear. Finally it went into first and then second (with some effort), but when I tried to shift into 3rd it wouldn't go into any gear again. I pulled over and with the motor stopped I could easily put the car into any gear I chose. I finally put the car into second with the motor stopped, and then started the engine while revving the engine enough so it wouldn't stall. This manaed to get me home.
I immediately thought that my clutch had gone out. I have never had a clutch go out on me before, though. I'm thinking that I should have had some warning. Everything was absolutely fine with my car, I haven't installed my turbo yet, and I was just cruising very normally. Do clutches just work 100% and then suddenly fail?
The slave cylinder and hydraulic plumbing look fine. The shift bushings on top of the transmission look relatively clean and lubed.
In a couple days I am going to Put in an ACT Clutch, flywheel, and change the tranny fluid to some Motul Redline.
If anyone has any insight into this problem, I would GREATLY appreciate it. Even a, "Yeah, its just the clutch idiot." or a, "Sorry, you've got major problems." would help me out.
Old Dec 27, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Bleed the clutch cylinder. It sounds like the clutch was not disengaging fully. Clutches rarely go out "suddenly". Last time that happened to me at a stoplight, it was the clutch cylinder leaking internally. I'd start there at least. THEN go on to the expensive stuff.
Old Dec 27, 2004
Drk01Civic's Avatar
I bled the system right after I posted and everything is still the same. I start the car up, push the clutch in, and nothing but grinding from any gear I try to select.
Old Dec 27, 2004
tinman's Avatar
Hmmm.... then perhaps the throwout bearing went. Sounds like you HAVE to take it apart. BTW, how many miles??
Old Dec 28, 2004
Overboost's Avatar
Overboost is an unknown quantity at this point
Damn that sucks. Mine always throws it out of 2nd and just started grinding going into 3rd. I took it to the dealership and they said it wouldn't be under warranty but just by driving it said it was probably a bent shift fork so I am also just going to upgrade and put in an ACT clutch, fix the broken parts and put in a Revo Short shifter. Should have it all in by the end of Jan.
Old Dec 28, 2004
Drk01Civic's Avatar
Yeah, I'm pulling the tranny tomorrow. I have 85,000 miles.
Old Dec 28, 2004
98oRange's Avatar
98oRange is an unknown quantity at this point
i just swapped my clutch to and ACT xtreme and 6puck.
check ebay for some good deals.
havent tested it yet but the thing sounds fine...
i just finished putting it together yestarday...
have fun with the axels...
Old Dec 29, 2004
Drk01Civic's Avatar
Dropping the tranny isn't as much work as I thought. I did a little prep work last night and it's ready to fall out. I just ordered the ACT HC5-HDSS and streetlite flywheel. How is the pedal effort with the xtreme & 6 puck? I want something that has good torque capacity but I daily drive this car and am sometimes stuck in LA traffic.
Old Dec 29, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Did you try re-lubing the shifter? That fixed my stiff-shifting problem.
Old Dec 29, 2004
98oRange's Avatar
Ill let you know today... I got the fluids in
Old Dec 29, 2004
98oRange's Avatar
No pedal effort at all. prolly might want a street disk but definately get the plate.
The clutch engags like there is no tomorrow.
Old Dec 30, 2004
Drk01Civic's Avatar
Ok, I pulled my tranny yesterday and one of the 4 springs on the clutch came out and was rattling around in there. I'll post pics of it when I get a chance to borrow a digital camera. While I have everything out, I'm changing any type of bearing, gasket, or seal I can think of. My new parts won't be here until next week so I'm without a car until then. It looked like I would have still had about 40,000 miles left on the clutch.
Old Dec 30, 2004
Not bad for a first clutch destruction.
Old Dec 30, 2004
98oRange's Avatar
if you buy a kit it comes with the throwout bearing and the alignment bearing. thats all you need to replace.
if you dont have a lightened flywheel I recommend it.
Old Dec 30, 2004
98oRange's Avatar
as for the shifter I lubed it with paintballgun oil. it shifts smooooth.
Old Dec 30, 2004
98oRange's Avatar
im stupid. I read that you bought a streetlite after i typed that.....
good luck breaking the flywheel free.
Old Dec 30, 2004
98oRange's Avatar
if you need help msg me. Ill be more than happy to tell you anything you wanna kno if you dont already.
Old Dec 30, 2004
Drk01Civic's Avatar
Thanks alot. It has seriously been a breeze, though. Flywheel is off. I had a friend of mine who is a tech at Honda come over and check everything out and he gave me a shopping list of seals and gaskets that needed to be, or would soon need to be, replaced in lieu of the throwout and pilot bearing.
Old Dec 30, 2004
98oRange's Avatar
sweet. I am at the sucky part... The break in period.
Have him get you some honda-bond. That stuf roxx
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
