adjustable fuel regulator
I searched everything in here and could not find so here goes:
I was curious if anyone had installed a B&M or equivelent universal adjustable fuel regulator. I can't seem to find one that is made for my 03 ex coupe, so universal seems the way to go, I put on a run of the mill cold air with no problems, It seems to give a little more hp off the line but, When I floor it it boggs down Im guessing that its becuase Im not matching the added air with more fuel? Thanks fellas..Jeff
Originally Posted by 4drcivic2k1
Good luck finding one. =)
The new civic/rsx has a returnless fuel system. The pressure is regulated in the fuel tank before the rail.
right, if you install a fpr, you also need to install a intank pump and modify your fuel rail and run fuel line for a return fuel set-up. Also, you would need a piggyback fuel computer to adjust the fuel. This should only be done for boost or n2o.
What you need is a safc........actually, you don't need anything cuz a intake will not make a difference at all. OBD II cars will automatically supply the sufficent amount of fuel needed.
Civicircus
Aug 6, 2015 11:58 PM
fred57
Aug 1, 2015 08:45 AM
Green02civic
Jul 27, 2015 10:48 PM
jzhartman
22
Jul 23, 2015 10:42 PM
