Manual trans service
Old Dec 17, 2004
return_2020's Avatar
return_2020 is an unknown quantity at this point
I just got my manual transmission service done on 03 civic ex. but got a question here. dealer showed me two different service for this, one where they connect the machine and flush out everything from the transmission and it takes about 5-6 qts of oil and costs $119.00, other where you just drain and fill the oil for $44.00 which takes about 2 qts of oil. I got the drain and fill change done for $44.00, i definately feel the difference, it feels like butter when you change the gear. just to confirm from any of you, is there a service like that where you connect the machine ? i thought that its only for the automatic trans only. please let me know, just curious.
Old Dec 17, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Power flush is never good for any engine parts. You'd need lubrication to move at startup. It is recommended go for drain-and-refill method for all applications.
Old Dec 17, 2004
flotsamm's Avatar
He's talking about a transmission, not an engine flush. But yeah, I didnt know they could power flush a manual tranny. Automatics yes, since you can flush it by using the tranny cooler lines.
Old Dec 17, 2004
Da1lyDr1ver's Avatar
^^^ he's correct. plus, when you do a power flush, some of the contaminents could wash back into your internal transmission parts which isnt good. just do regular intervals of drain and refill if you have an automatic car. oh, manual cars, to my knowledge doesnt require a power flush. my dealer told me that theres an option to do a power flush on an automatic car because it has a torque converter, so extra fluid gets stuck there. manual cars dont have a torque converter so when you drain the fluid, all of the fluid actually comes out.
Old Dec 17, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
It's just a time saver for shops, and as said above it can cause problems.
Tim1959
Jun 3, 2015 08:15 PM
oneheadlight
Apr 29, 2015 11:30 PM
davidpaustin
Apr 29, 2015 02:23 PM
2k2civic
Mar 18, 2003 06:19 PM
SgCivic
Bolt-on Engine Performance
Nov 15, 2001 07:31 PM
