reverse actin weird
Old Jan 27, 2005
Tipsy_AA's Avatar
Tipsy_AA has a little shameless behaviour in the past
reverse actin weird
my reverse gear has been actin weird....i have an 5 speed 05 with almost 4000 miles on it. when i put the gear into reverse, feels like it gets jammed or hard to put it. anyone else have this problem??...
Old Jan 27, 2005
2k2silvcivic's Avatar
2k2silvcivic is an unknown quantity at this point
Ya the samething happens to me. I dont know the cause though. I somethines have to put it back in nutral and then let the clutch out and try again till i get it lol. i hope thats normal.
Old Jan 28, 2005
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
According to my Honda dealer mechanic, this is normal. It has to do with the reverse gear only having a single synchro while all forward gears have triple synchro. If the single synchro doe not match exactly, it becomes difficult to engage into reverse gear.
You can make it a bit easier by shifting into reverse. While still pulling into reverse, slowly lift the clutch a bit (not enough to enage the flywheel). The shifter should click into reverse much easier.
Old Jan 28, 2005
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Shift to 1st then to Reverse.
Old Jan 28, 2005
MishBallzEM2's Avatar
I'm The Ballz Of 7th Gen
MishBallzEM2 is an unknown quantity at this point
yeah thats normal..happens in like all 5spd hondas
Old Feb 13, 2005
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
Yup, I hate it, too. I usually put it in first, then down to reverse. That does the trick sometimes.
Old Feb 13, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
yup, this is normal. happens to me and also happens to my friends si. but however this does not happen to my friends spec v. when he shifts to reverse you cant even hear it, but for us, you gotta hear to click to know that were in reverse.
Old Feb 13, 2005
GuliziaN's Avatar
Powered by Honda...
GuliziaN will become famous soon enoughGuliziaN will become famous soon enough
My 05 feels great in and out of reverse... Not sure what is causing your problem.
Old Feb 13, 2005
^^what most of them said, its pretty normal.. either stick it in first, then reverse, or, if it's still being a bitch, lift up the clutch a little while pulling into reverse...
Old Feb 14, 2005
starstryke's Avatar
starstryke is an unknown quantity at this point
my 91 did that a lot.. wish my 01 was a stick... miss the driving fun it provided.
Old Feb 14, 2005
im stock now! T.T
its normal.......
Old Feb 14, 2005
starstryke's Avatar
just remembered a talk I had with a honda mechanic.. he mentioned that the reverse gear was located farther right than other car makes and that it's harder to shift into and stiffer.
velozp
Dec 13, 2015 11:28 AM
ThatGuy913
Sep 28, 2015 05:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
BBrosario
Sep 17, 2015 07:51 PM
Bricoleur
Sep 9, 2015 12:30 PM
