Engine revs high and low after alternator replacement and throttle body cleaning . .
Old Sep 9, 2015
Bricoleur's Avatar
Bricoleur is an unknown quantity at this point
I have a '95 Honda Civic DX, 4 door, 1.5 L engine, automatic transmission. After having another rebuilt alternator put in and the throttle body cleaned, the engine now revs high and low in a continuous cycle, especiallynwhile the transmission is in either Park or Neutral. but it also occurs while in Drive but , this situation (high rev, low rev cycle) lessens a bit when I turn on the headlights and air conditioner, but it is still there, just not as forceful.
When the transmission is in Drive or Reverse, this high revving, low revving goes away when the car is stopped ( with brake pedal on) but when driving at low speeds, there is some of this high rev/low rev -- just not as much as when in Park or Neutral.
The car was not doing any of this until the new alternator was put in and the shop clearned the throttle body, (which, BTW, I did not ask them to do). I wonder if that has something to do with this? Maybe clearning the throttle body messed put gunk or gummed up the IACV?
The background on the rebuilt alternator: Under this site's subforum for I.C.E. and Electrical for 5th generation Civics, I posted yesterday about my replacing the original alternator after it developed overcharging problems.
I am thinking along the lines of a clogged/dirty IACV, bubble in the coolant system, or some weird ECM issue.
Any ideas would be helpful.
Old Sep 9, 2015
Re: Engine revs high and low after alternator replacement and throttle body cleaning
Take it back to the shop that did the work, because it did not do this until they touched it.
davidpaustin
Apr 29, 2015 02:23 PM
green01civic
Apr 29, 2015 01:36 PM
mievil
Apr 28, 2015 11:02 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
