p0138 code ecu
Old Nov 6, 2004
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
p0138 code ecu
I just plug in my code scanner and i got this p0138 high volts(bank 1,sensor 2).
I have test pipe(stright pipe) from hp. I not that worry it is my secondary o2 sen. I'm worry about the pimary o2 sen. What do the code mean it is my second o2 or pimary? can you really tell?
Old Nov 7, 2004
Storm897's Avatar
Storm897 is an unknown quantity at this point
Try these websites linked below for help:
Site #1
The site above recommends replacing the O2 sensor, and resetting the ecu by unplugging the batery cable.
Site #2
From the site above:
> On the P0138:
> P-0138 1/2 O2 Sensor Shorted to Voltage
> SYMPTOM
> P-0138 1/2 O2 SENSOR SHORTED TO VOLTAGE
> WHEN MONITORED
> With the engine running for more than 2 minutes and coolant temperature
> above 170 degrees F .
> SET CONDITION
> The oxygen sensor voltage is above 1.2 volts .
> POSSIBLE CAUSES
> 1/2 O2 sensor signal circuit shorted to voltage
> 1/2 O2 sensor wiring harness observable def
> 1/2 O2 sensor wiring harness or connector intermittent def
> 1/2 O2 sensor connector terminals observable def
> 1/2 O2 sensor defective
Site #3
The people in the above post received this error after installing after market exhausts.
Civic15
18
Sep 19, 2017 07:48 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
