Power Stearing Fluid
My power stearing fluid resvoir isnt able to stay full about a week and a half ago i filled it up with a whole bottle of fluid and its already below the line right now and make the sound like its straining or whining, any idea why?
should i just take it honda?
Go to an independent shop. they will charge less.
You really don't need someone to tell you whether you need to take it to a mechanic. If you have a problem with your car, and you can't figure it out, it is very logical that a professional would do a better job. All everyone here can do is guess at your problem and suggest fixes. Ultimately, you still have to take care of it.
true but i guess my real question was should i take it to honda or try and find another shop? also what kind of shop? i looked at it when i parked and nothing seemed leaking from the resvoir on down so maybe its the pump which either way its gonna be expensive right? i was also just asking for tips on how to check what part of my car might be wrong
ok this is how u fix ur problem
go to the nearest auto parts store
ask for oil leak detector
put it in ur ps resevoir
go buy a black light
drive home
with the black light in the garage fash it any where the ps componets are
where u see a bright green
U FOUND THE LEAK
the rest is up to u
drive home
U FOUND THE LEAK
the rest is up to u
drive home
U FOUND THE LEAK
the rest is up to u
drive home
U FOUND THE LEAK
the rest is up to u
is any of that stop leak stuff at pep boys any good , when i went in to get more fluid ( i know temporary solution before it drains again) i saw they had some no leak things for power stearing saying will stop small leaks and what know, worth it , any good? any harm if i use it?
yea ive looked but tis not like i leave my car for an hour and see a puddle or its dripping out, just thought i would try a $5 dollar fix first then, if not it then take it in, is this not something that should be covered under warranty?
thanks, some people have mentioned they have the honda care warranty but i dont think we ever got that, so im pretty sure its just the basic one
covered under warranty they said it was the power steering rack leaking, and they replaced , teh box assy. and washer, tie rod l, is the name of things they replaced
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
hans.pcguy
Jul 12, 2015 12:19 PM
