ABS and SRS light come and go
Old Dec 19, 2004
wonderz's Avatar
wonderz is on a distinguished road
I am having this problem where sometimes when I am driving, my ABS and/or SRS will come on, and then turn back off after a few seconds. Also not sure if its related, sometimes my cd player would stop while playing a song and then resume after a few seconds too, and also sometimes when I turn the hazard light on, my interior light would dim (blinking bright-dark-bright-dark) as the signals are blinking. However the cd player and the light problem didn't happen at the same time as the ABS and SRS light thing.
Any suggestions?
Old Dec 19, 2004
Make sure the battery terminals are clean and tight.
Old Dec 19, 2004
wonderz's Avatar
how does the battery terminal have to do with ABS and SRS light? 'cause none of the other lights came on in the cluster other than ABS and SRS.
Old Dec 19, 2004
streetglower's Avatar
basically I agree with gearbox, check your battery connections. I think you have a loose connection somewhere.
Same thing happened in my friends car, his brake light would go on and off all because of a loose ground.
Old Dec 19, 2004
My terminal was loose and the car wouldn't start, immobilizer, srs, abs, and domelights would dim. Lots of problems when things don't get power.
Burnout
Jul 15, 2022 10:24 PM
Blazz
May 25, 2015 10:56 PM
cukaracha
May 16, 2015 02:11 PM
XtremelySpoiled
Dec 13, 2001 08:47 PM
SimDogg
Nov 27, 2001 04:20 PM
