power windows
Old Dec 7, 2004
xtreme26's Avatar
xtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura aboutxtreme26 has a spectacular aura about
power windows
how much would it cost to replace the motor for power windows, and can i replace it myself, an how?
Old Dec 9, 2004
streetglower's Avatar
well first you need to find out if that is even the problem, next if it is, then you need to price the part, then call around and ask for install prices.
And yes you can replace it, you can replace anything yourself, as long as you know what your doing.
Old Dec 9, 2004
acurastype01's Avatar
w00t
acurastype01 is an unknown quantity at this point
itd be hard to do but you could probably do it yourself...parts might be alittle costly
Old Dec 10, 2004
solar's Avatar
solar is an unknown quantity at this point
I believe you have to replace the whole track assembly because the motor is intigrated into it. They're all different depending on the make, year and model so find out before you go and take things apart. As far as replacing it, like mentioned above make sure it is the motor and not a switch, fuse, bad connection, etc. etc.
To replace it you need to remove the door panel and some other hardware. I know that on some of the assemblies I've replaced you need to drill and grind out the rivits, which are much bigger than normal. Then you need a huge rivit gun to pop the new ones back in. Its not something you should learn on your own, because there's many little "tricks" to learn, but if you are going to do it buy a manual and read the instructions over and over again before you attempt it. Good Luck.
Old Dec 10, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
In situations like this, I'd pay a rep. professional to do it. By the time you are done with this, it will probably cost you not much more to have someone do it for you hence they have the right tools.
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
1khilari
Jul 9, 2015 08:12 PM
ballmich
Jul 9, 2015 11:59 AM
hayden55
Jul 8, 2015 11:38 PM
cgavin1
Jul 7, 2015 07:10 AM
