second gear slipping
Old Dec 10, 2004
AznChinksta's Avatar
AznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really nice
hey gusy whenever i shift into second second gear pops out and it grinds, it doesnt always do this but it happens a lot. Sometime i have to jus hold it in second so it wont come out. Has this happened to anyone here
Old Dec 10, 2004
Zzyzx's Avatar
Autocross Junky
I believe there is a TSB out on that.... it should be covered under waranty.
Old Dec 10, 2004
mexinaction's Avatar
yea same thing happens to mine, and it is an 04, maybe i will take it to dealer to have it checked out
what is TSB?
Old Dec 10, 2004
Zzyzx's Avatar
Autocross Junky
"Technical Service Bulletins (TSB'S) are fixes to known problems that dealer service departments have alerted the vehicle manufacturer. Recurring customer complaints, part failure, and other mechanical trouble is compiled into a TSB. Usually only new car dealers have access to TSB'S, and the amount of money and time they can save diagnosing and repairing your vehicle is phenomenal. Technical Service Bulletins can save you tons of valuable time and money.
Old Dec 10, 2004
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
If there is a TSB out for a problem and you take the car in to get that problem fixed under warranty, is the dealership obligated to fix the problem at their expense? I took my car into the dealership for a TSB item once and they refused to do anything about it—they said it was "normal" for Civics to have the problem.
Old Dec 10, 2004
scatman's Avatar
Still in the game...
maybe its because you can probably outrun an s2k with ur skills and shift so hard the gears wont hold it in
^^--looks down at his own sig
Old Dec 10, 2004
Zzyzx's Avatar
Autocross Junky
IN light that you apparently street race the car... you may have damaged the dog teeth on the 2nd gear collar enough that they will no longer hold them selves in to the gear...
Old Dec 11, 2004
HaXeDupINC's Avatar
HaXeDupINC can only hope to improve
that happened to my friend then one day his clutch pedel dropped on the floor and he couldnt drive it...honda replaced his tranny...i forget what the matter was but honda should cover it...oh yea he had an 01...it happened like a year after he got it
Old Dec 15, 2004
sohcvtec2001ex's Avatar
sohcvtec2001ex is an unknown quantity at this point
hey haxedupinc the same happen to my 01 ex and they had to replace the transmission a broken trans mount and a new front end
Old Dec 15, 2004
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
sounds like the same problem i have, second gear is pretty rough, and takes a good amount of force to get it in gear. If I take my car to the dealer to get it fixed, will they take care of the problem even I have a short shifter installed? I have the neuspeed short shifter, so its drilled in.
Whitexj
Sep 30, 2015 02:04 AM
winanthony94
Sep 25, 2015 09:05 AM
beanhead
Sep 24, 2015 12:04 PM
BBrosario
Sep 17, 2015 07:51 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
