I tried to search but nothing... Steering wheel alignment
Old Jun 16, 2006
nox_slang's Avatar
nox_slang is an unknown quantity at this point
My vehicle has just been aligned and the technician has told me that the steering wheel coloumn is not alligned with the steering wheel rack. Is there A diy for this? lol im too cheap to pay the $ and I really have to get this done soon (all though Telly my great friend has offered aid) I still must have this done by work monday.
Thank you kindly guys. I will send porno to those who ask and help! lol
Old Jun 16, 2006
hmm never seen that done diy before. and how does that even happen? accident?
Old Jun 18, 2006
nox_slang's Avatar
yea... i guess the mechanic took out my steering whell column and didnt put it back properly
Old Jun 18, 2006
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
usually they center the steering wheel when they do an alignment. They don't take out the steering column when they do an alignment, all they do is adjust the tie rod ends; something sounds fishy. Most places will only adjust the toe on the vehicle, take it to a place that uses Hunter alignment machines because those use lasers to measure how much it's off.
Old Jun 18, 2006
tfnaaf's Avatar
BLDNPSI Mod
They dont use lasers, its infared lights. And Hunter Engineering is by far not the best system on the market. They should change the name of the company to Hunter RE-engineering, being they cant come with an alignment machine on thier own with out stealing others companys ideas. ..... Rant /off (BTW i HATE Hunter aligners and have to use one daily )
Old Jun 19, 2006
buckshizzo's Avatar
damn i can tell you hate hunter machines, i just thought hunters were good because they use the infared lights and the mechanic who did my alignment did a good job. What are good machines I can look for?
Old Jun 19, 2006
tfnaaf's Avatar
BLDNPSI Mod
Any of the machines will give good results, its all a matter of what the tech can do with the machine he has I just enjoy bad mouthing the hunter machines in general .... lol
Old Jun 19, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
coats....if they make them.....I wanna say we have a hunter at our place...but its all about the person who uses it...and my man Mike is the best at aligning the cars and fixing the suspensions....come back so tight and even you'd think it came off the assembly line....
Old Jun 19, 2006
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
You need to remove the steering wheel from the rack and move it over a tooth or two. It should require only a couple of bolts and a good pull. You will need to remove the plastic around the column and it may be best to remove the drivers seat (to allow for more working area). It is really a simple fix. It is easy enough to remove it and put it back on a couple of teeth off.
honda200192
Suspension
Oct 27, 2019 12:23 PM
honda200192
May 31, 2015 05:57 PM
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
RickyRocket
Nov 30, 2001 10:14 AM
