problems starting sometimes
Old May 3, 2006
adioskate12's Avatar
adioskate12 is an unknown quantity at this point
Ive been having a couple problems with my 02 ex not starting right somtimes, once and a while, you still get in and try to start it and it will just turn....I stopped and then I tried again and it starts fine....its done this a few times, is there any reason that causes this? or how do I go about fixing this?
Old May 9, 2006
Jdm01Em2's Avatar
Jdm01Em2 will become famous soon enoughJdm01Em2 will become famous soon enough
had the same promblem a year ago and replaced the starter and then everything was fine it would start most of the time then out of no where it stop starting then like a hour it will start sounds like the same promblem
Old May 9, 2006
ya it happens rarely for me but i guess could be worse. its prolly vapor lock or something. just keep it in ON position a few seconds before cranking. helps but it will still happen. nothings perfect.
Old May 9, 2006
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
it cranks but wont start sometimes if the immobilizer cant read the key. check to see if the green key shaped light on the dash blinks while you are cranking it and its not starting.
CarStuff
Dec 6, 2020 12:52 PM
black2k1vtec
Dec 6, 2001 09:49 PM
OoSiLvErCiViCoO
Nov 14, 2001 11:35 AM
OoSiLvErCiViCoO
Nov 14, 2001 06:21 AM
