Greddy Evo2 Exhaust Problems
Old Apr 25, 2006
M4X's Avatar
M4X
M4X is an unknown quantity at this point
I've had the exhaust for more than a year with no problems. Recently however, that has changed. A few months ago a rattling sound began to happen when I stepped on the gas. It sounds like ball bearings in a metal can. I finally put it on a lift and checked underneath for anything it could be hitting. Tons of clearance, it wasn't that. I checked by the canister giving it a few taps. It seems my baffle some how broke off in the muffler. I called greddy and they said I needed a whole new exhaust! That seems a little extreme. My idea is to see if I can remove the baffle by disassembling the exhaust. If it's completely detached inside it should just fall out. That is, unless it's bigger than the hole it's trapped behind. Are there any dangers or consequences to doing this? Any help would be appreciated. The sound is driving me insane.
Old Apr 26, 2006
familycar's Avatar
are you sure its not your cat or a piece of your cat inside the muffler. becasue even if you get the peice out if the cat is chunking up then the problem will just return
Old May 10, 2006
M4X's Avatar
M4X
A piece of my cat? What do you mean? Is there any way to check?
Old May 10, 2006
familycar's Avatar
your catylitic converter not your house cat! LOL j/k
unbolt the cat pipe and look to see if the grate is still inside the cat and there are no missing peices
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
cukaracha
May 16, 2015 07:36 PM
SugarRay
Dec 13, 2001 09:58 AM
meels808
Dec 1, 2001 02:44 PM
MY01HX
Nov 12, 2001 04:25 PM
