Civic won't start!!! PLEASE HELP!!!
Old May 29, 2006
FOOP's Avatar
FOOP is an unknown quantity at this point
So...I go out to my car this morning and it won't start. Not only will it not start but nothing comes on when I turn the key. No dash lights, no interior lights, nothing. I checked the battery and the porthole is green. The connections to the battery are good. I checked all of the fuses etc. And nothing. Tried to jump the car and still nothing. And the digital readout for my capacitor for my system is off too. I still think the battery is dead, but does anyone else have a better idea of what it could be? Has anyone else had the same experience?
Old May 29, 2006
R1Style's Avatar
If nothing turns on at all when you turn the key... then it's your battery or your battery connection.
If you have a volt meter, test the battery. Also check all the wires for any loose connections and make sure the battery terminals are corrision free.
Old May 29, 2006
zen_master's Avatar
definitely disconnect all your sound system first....
try jump starting the car...
Old May 29, 2006
CraigW's Avatar
If the battery IS drained you will have to charge it for a while before attempting to start it. A battery charge would work better than a jump start.
If the jumper cables are hooked up do the dash lights start to work then ??
Old May 29, 2006
FOOP's Avatar
The dash lights do NOT turn on when the jumper caples are connected. I am going to take the battery to AutoZone so they can check for charge and charge it if it needs it. Thanks for your help guys. I will let you know what happens.
Old May 29, 2006
zen_master's Avatar
make sure you check all the fuses...
there is a fuse for battery too....check that...
Old May 29, 2006
FOOP's Avatar
Is the fuse for the battery in the engine bay fuse box?
Old May 29, 2006
zen_master's Avatar
it's in the engine bay...
it's big. lol.
make sure you check all the other fuses too...ECU fuse for sure..
Old May 29, 2006
FOOP's Avatar
I replaced the battery and everything is ok!!! Thanks everyone
Old May 30, 2006
zen_master's Avatar
careful, man...
batter might not be the sole problem. especially when u said the eye on the battery was green...
might be ur alternator not properly charging your battery.
Old May 30, 2006
get a free charge system check from an auto place to be sure, advance autozone kragen all do it free.
Jonnie.
Jan 13, 2019 11:21 AM
vtec92
May 4, 2017 03:20 AM
Braun
Apr 23, 2015 09:03 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
