Misfire out of ideas!!!!
Old May 2, 2006
nismostreets21's Avatar
nismostreets21 can only hope to improve
ok so yesterday we hooked my car up 2 the scanner and it threw the code loss of compression cylinder 1...due to spark plugs so i put new spark plugs in it...check engine light came back on this morning and it then threw the code misfire cylinder 1... checked the coil packs resistance,head gasket, valve cover gasket,intake manifold gasket...and had the stethascope to see if the injectors were functioning properly, and checked the compression everything was right were it should be but yet i am having a serious misfire please help
Old May 2, 2006
djmota's Avatar
swap a coil from another cylinder to the problematic one. see if the problem travels with the coil.
Old May 5, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
95% of the time you need a new coil....
Old May 8, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
i have to agree. if you tried everything but the coil then its the coil
Old May 11, 2006
i actually forgot to say that i did check the resistance of it all the same
thana
Jun 15, 2020 07:05 PM
danace99
23
Jun 28, 2015 08:49 AM
paul.collins92
Jun 25, 2015 12:12 AM
zaboomafoozarg
May 30, 2015 09:21 AM
davidarenberg
May 16, 2015 08:45 AM
