SRS light / Seat Removal
Old May 15, 2006
Honda01's Avatar
Honda01 will become famous soon enoughHonda01 will become famous soon enough
I have to pull up my carpet as I had a leak on the drivers side somewhere, after I removed my drivers seat to access the carpet, and subsequently fix the leak and put it back together, I now constantly have the SRS light.
Taking out the drivers seat involved un plugging the 2 plugs attached underneath, plus taking out the seat belt restraint holder bolts [down at the bottom, 2].
I don't think i did anything when I was under the dash removing the carpet.
Would this have anything todo with the two plugs I found under the seat - which I beleive are put back together properly.
Could i have anything to do with the seat belt restraint holder not be tightened properly.
Any suggestions
Thanks guys
Old May 16, 2006
Honda01's Avatar
Sorry, I bumped it, but I missed the 'sticky'
I'm looking at how to fix it now.
I'm in Canada, so I can't order from H and A to get the part... so i'm trying to see how this works.
In the sticky, 'jay78' posted a picture of what this is - I don't really get it, is it just one piece of wire, bent in half so as to complete a circut?
Old May 16, 2006
Pharoh's Avatar
Bobaganoosh!
well....Yellow plug is SRS. If that was messed up then you would have a problem with the light going off. Check the connections carefully. Unless you yanked them out by accident when removing the seat I don't see why it would be acting up. It's been awhile since I did this but none the less...just recheck the connectors.
Old May 16, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
well to reset it i used 2 speaker wires instead of the paper clip cause its easier to work with(remember to strip them so it exposes the copper or silver wires). basically u unplug that yellow plug on the fuse box take the speaker wires put each one in each of the holes where the prongs or w.e they are called then the other end u touch them together.
Blazz
May 25, 2015 10:56 PM
jimmyfloyd
May 20, 2015 07:06 PM
cukaracha
May 16, 2015 02:11 PM
bo_red
Transmission
May 3, 2015 09:14 PM
SimDogg
Nov 27, 2001 04:20 PM
