Brake lamps don't work (rear brake lights and the small one against hte rear window)
all my brake lights don't work. but everything else works in the rear... reverse lights, night lights.
the brake lamp maintenance indicator is on.
do you guys think all 3 of my bulbs just so happened to blow out at the same time? or is it a fuse? or is it something else?
does anyone know where the fuse is located for this? i looked at the manual and i assume it's in the fusebox under the hood. the fuse looks perfectly fine as the metal piece isnt disconnected.
any ideas? Thanks.
any ideas? Thanks.
Do you mean the brake indicator that comes on when the parking brake is pulled ??
#7 / 15 Amp, in under-hood box should be the fuse you checked.
Other than the fuse the brake switch is the other likely thing to check.
tylerginevan
Apr 27, 2015 12:29 PM
