$$$$$$ How Much Will This Cost?????
Old Jun 7, 2006
nighthawk1903's Avatar
nighthawk1903 is an unknown quantity at this point
I Have an 2003 civic with a bad input shaft bearing any one out there replaced this before an if so how much am i lookin to spent??
Old Jun 7, 2006
Jdm01Em2's Avatar
Jdm01Em2 will become famous soon enoughJdm01Em2 will become famous soon enough
if you know somebody who can fix a clutch they can fix that. When mine went i went and got a performance clutch the replaced the input shaft bearing so you are lookin at 200 to 300 dollars
Old Jun 7, 2006
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
a lot
Old Jun 8, 2006
jmj10585's Avatar
jmj10585 is an unknown quantity at this point
The part itself is only $23 from honda, the labor will be comparable to having your clutch replaced and you might strongly consider replacing the clutch while you have them replace the bearing; preventive maintenance. Labor will probably be around $200. If you are mechanically inclined, you might consider following the how to on replacing your clutch and replace the bearing yourself, it'll save you a lot of money and should only take 4 or 5 hours if you have a knowledgable friend there to help.
solarpunk70
Apr 12, 2016 11:43 AM
Whitexj
Sep 30, 2015 02:04 AM
curaze
Sep 22, 2015 08:27 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
