Noise Diagnosis ..
Old Jun 23, 2006
dsearfass's Avatar
dsearfass is an unknown quantity at this point
Noise Diagnosis ..
There is a low pitch mechanical humming noise coming from the front of the car. It's a 2001 ex 5sp. The humming starts around 40mph and I can hear it up to 60 mph ... it does not increase in pitch but it does seem to get louder with more speed. Atter 60 I'm sure it's still there but I can't hear it because of wind/tire noise. It is not related to rpms .. I can put the vehicle in neutral and still hear it .. in fact I can shut the car off and still hear it. I did some searches and saw some people with alternator problems .. but I think I can rule this one out since the sound is not dependent on engine rpm. Im not ruling the wheel bearing out but steering does not affect the noise either. I checked the tires they seem fine. There is nothing stuck in them and they are not overinflated. Is there something that turns with the wheel at all times? Is the AC compressor on this loop?
Thanks ahead of time for any help,
-dave
Old Jun 23, 2006
CivicDuty's Avatar
CivicDuty is an unknown quantity at this point
I would say wheel bearing. The trick now is finding out which side.
Old Jun 23, 2006
dsearfass's Avatar
I'll try to check the wheels for vertical play tonight ...
The front also makes a cracking sound when I turn the wheel from a stand-still ... I wonder if that could be bearing related as well ...
Thanks for the reply .. it's appreciated.
Old Aug 27, 2006
mohakem's Avatar
mohakem is an unknown quantity at this point
Same probelm
I am experincing the same problem and went through the same diagnostic process.
What was the resolution and how much was it?
Old Aug 27, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
unbalanced tires? whens the last time you rotated your wheels?
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
tooly145
Sep 5, 2015 01:05 AM
jpat21
Sep 3, 2015 11:32 PM
