driver door lock wont lock
Old May 22, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
this has happened to me randomly (at least 5 times since the past 3 years ive own my civic). sometimes my driver side door lock wont "lock" when i hit the unlock/lock switch located on the door panel. nor will my keyless entry lock it. however, my keyless entry lets me unlock the vehicle. so it leaves me locking the drivers door manually in order to secure my civic. i was hoping this issue will go away like the past 4 times, but its been like this for almost a month now.
heres things that i know of:
-the door lock/unlock tablet (the actual locking w/ red plastic tab) will move up and down if i use my fingers but very stiff
-passenger side is perfectly fine
-late 2003 model civic (did we have a recall on this?)
Old May 23, 2006
billiardini's Avatar
billiardini will become famous soon enoughbilliardini will become famous soon enough
your battery in the door that controls your power windows and door locks is most probably almost dead.. check the battery in the door panel.. new one is about 30 bucks on the drivers side..
Old May 25, 2006
s13_240sx_92's Avatar
s13_240sx_92 is an unknown quantity at this point
Battery in the door???? huh? There is a battery in your door panel? please explain.
Old May 26, 2006
CiviC02's Avatar
CiviC02 is an unknown quantity at this point
try pullin the door handle on the inside out and hold then hit the lock button at the same time that will lock the driver side so that you wont have to use your key to lock it from the outside only if you have the key out of the ignition.
Old May 26, 2006
2k2whitecivic's Avatar
2k2whitecivic is an unknown quantity at this point
I am haing this same problem with my car. mine is an 02 civic ex if that helps . so do I need a new battery or what?
Old May 30, 2006
As far as I know there isn't a battery in the door. Seems likely that its an actuator.
Old May 31, 2006
jimbo75's Avatar
jimbo75 is an unknown quantity at this point
my 02 ex has the same problem on driver's side, but it works on most rainy days.
Old Jun 30, 2006
Stearic's Avatar
Stearic is an unknown quantity at this point
Saying there is a battery in the door is the dumbest thing i've ever heard of. There is no such thing as a battery being a door. The only way there would be a battery in the door would be if someone put one in there after they bought it for some reason (what that reason is i have no clue).
Old Jun 30, 2006
blackBDMcivicLX's Avatar
For every sprinkle I find, I shall kill you.
blackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant future
No there is no battery. It's your door lock actuator. It's around $30 (estimate) for the actuator. Or you can spend $80 (estimate) on the entire door lock assembly. Difference between them... Door lock assembly is basically a bolt-on part. Pull the bad out, put the new in. The actuator is a little harder. Pull the current door lock assembly out, then figure out how to get just the actuator off and put the new on. Not as easy as it sounds, but also not something you need to pay someone loads of cash to do.
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
h4ldol
Jun 3, 2015 03:26 PM
MamaBear2015
May 18, 2015 07:37 PM
MamaBear2015
May 3, 2015 02:17 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
