HID problem/ stock fog light
Old Jul 11, 2002
Erichyung's Avatar
Erichyung is an unknown quantity at this point
I have hid's and when i turn on my low bean, my car thinks the high-beam is on, so the blue high-beam light turns on my gauge.
The problem is that I can't have my fog light turned on because it only turns on only when my car is at low-beam mode, and not high-beam.
I want to be able to turn on my foglight anytime i want, wether headlight is on or not. Do you guys have any idea how i can work the circuit to do this?
Old Jul 13, 2002
pdxbiker's Avatar
pdxbiker is an unknown quantity at this point
I had that problem with my HID's too when I turn on the lights the high beam idicator comes on. I found out that the wiring was wrong. You either have the high beam lead instead of the low bean lead to the relay or both high and low beam leads are hooked up to the relay. You could have a seprate switch to turn on fog lights.
Old Jul 13, 2002
Erichyung's Avatar
so what did you do to make your foglight to work? I guess I can make a seperate switch for the foglight, or cut the high-beah lead from the relay.
Old Jul 13, 2002
pdxbiker's Avatar
I don't have fog lights.
Old Jul 13, 2002
Erichyung's Avatar
okay
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
