Melted fuse box
Old Jul 11, 2002
dullard's Avatar
dullard is an unknown quantity at this point
Melted fuse box
Hi I just joined, so sorry if this has been discussed before.
My 2002 Civic is the the shop after it stalled. There they discovered the fuse box had melted. After discussion with national Honda service technicians they told me it was a design flaw and is relatively common in 2001 and 2002 Civics. Basically I was told the fuse box is too close to the hot engine.
Is this a common occurance? Will they just replace it with another fuse box that will melt on the next hot day? Or has Honda come up with a permanent solution?
Old Jul 11, 2002
lemoncivic's Avatar
lemoncivic is an unknown quantity at this point
I have not seen any posts on thsi topic previously. Sounds like a very serious "Design Flaw". But from this generation's CIVIC, far from a surprise. I can't believe that the words "design flaw" and "HONDA' are so often said in the same sentence lately.
Old Jul 11, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Quote
[hr]Originally posted by: dullard
Is this a common occurance? Will they just replace it with another fuse box that will melt on the next hot day? Or has Honda come up with a permanent solution?[hr]
i have never heard about that in my life. Did you see what the fuse box looked like when it was melted? Any pics? I would be curious to see how melted it actaully was.
Old Jul 11, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
Design flaw in a honda? Blasphemy!!!!
Old Jul 12, 2002
jro's Avatar
jro
jro is an unknown quantity at this point
i've never heard of a problem like that...the box is pretty far away from hot parts from the engine.
plus wouldn't other plastic parts melt as well...i.e. the wire cover, resonator and intake plastic? i really don't know. i'm just speculating.
{i hope it's all right if i use a pic off your site, ph0ng}
-jro
Old Jul 12, 2002
bhaz413's Avatar
Quote
[hr]Originally posted by: jro
-jro[hr]
eww drity engine [IMG]i/expressions/face-icon-small-smile.gif[/IMG] j/k
Old Jul 12, 2002
dullard's Avatar
Just got it back - and it runs fine.
I was in quite a hurry when I dropped it off and picked it up - so I didn't ask to look at the box. However there isn't much sign of melted plasic on the other parts - thus I think it just deformed more than anything else - just enough to start interupting the fuse operation.
From what I've been told, Honda was very interested in the operation that day - air temperature, components that were turned on, etc. It was 97°F with AC running, headlights running, and CD player running. I think the combination of things produced just enough heat to cause problems. So Honda is keeping track of the conditions that cause the melting to occur. The technicians said they have seen it with several 2001s and now they are just beginning to see it with the 2002s.
I don't know enough about engines to know which type of plastic is used and where. However, there is an enormous difference in melting temperature between different plastics. Thus is it possible that the fuse box has a lower melting temp than the other engine plastics?
Old Jul 13, 2002
dragoon's Avatar
was your car sitting in the sun a long time before you drove it? seems like it would take a LOT of heat to melt something so far away from the engine!
Old Jul 15, 2002
Boost's Avatar
Boost is an unknown quantity at this point
it almost sounds like more of an electrical short. the same thing happened to me a few months ago, but that was due to an improper ground
Old Jul 16, 2002
bhaz413's Avatar
Quote
I don't know enough about engines to know which type of plastic is used and where. However, there is an enormous difference in melting temperature between different plastics. Thus is it possible that the fuse box has a lower melting temp than the other engine plastics?[hr]
very unlikly. But you have to ask this question, if the fuse box melted, why didnt the plastic on the valve cover melt?
Old Jul 20, 2002
Niter1dah's Avatar
Niter1dah is an unknown quantity at this point
I seriously doubt it had anything to do with heat from the engine. The fact that your fuse box melted is really interesting still. Guys at Honda didnt say anything about the real cause tho? Mabye something check out.
h4ldol
19
Jul 28, 2015 01:01 AM
Dave1984
Jul 22, 2015 06:10 PM
Civic65
Jul 19, 2015 10:13 AM
