heh, I just did a search for 2k2 service bulletins...
Old Jul 3, 2002
sorphin's Avatar
sorphin is an unknown quantity at this point
heh, a nice full page of them. time to print these buggers out and go back to my dealer w/ them and the other 3 i have.. eesh. you think after 2 years w/ this "new model" they'd have something right..
Old Jul 3, 2002
thirdhonda's Avatar
thirdhonda is an unknown quantity at this point
Did you find complete TSBs, or just summaries? Where did you find them, NHTSA?
Old Jul 3, 2002
badcivic2002's Avatar
badcivic2002 is an unknown quantity at this point
You really should post where you found these problems, and if possible a list of them. So I can keep an eye out aswell.
Old Jul 3, 2002
nihao4587's Avatar
nihao4587 is an unknown quantity at this point
Correct me if they are not right--
Component Description:1.ELECTRICAL SYSTEM NHTSA Number: SB629301
Bulletin Number: 010102
Bulletin Date: JAN 2002
Vehicle: 2002 Honda Civic
Summary:SUBJECT REGARDING FAULTY GROUND G551 FOR DRIVEABILITY PROBLEMS. *TT
Component Description:2.ENGINE NHTSA Number: SB631014
Bulletin Number: 010302
Bulletin Date: MAR 2002
Summary:CUSTOMER COMPLAINTS OF A GROWLING NOISE FROM THE ENGINE AREA. *TT
Component Description:3.VISUAL SYSTEMS:GLASS:WINDSHIELD NHTSA Number: SB629100
Bulletin Number: 01072002
Summary:SUBJECT REGARDING LOOSE OR DEFORMED UPPER WINDSHIELD MOLDINGS. *TT
Component Description:4.AIR CONDITIONER NHTSA Number: SB627516
Bulletin Number: 011101
Bulletin Date: NOV 2001
Summary:SUBJECT REGARDING AIR CONDITIONER CAN NOT BE TURNED OFF WHILE IN DEFOG. SUBJECT REGARDING FRONT WINDOWS WILL NOT FULLY ROLL DOWN. *SLC SUBJECT REGARDING MULTIPLE SAFETY RESTRAINT SYSTEM DIAGNOSTIC TROUBLE CODES *SLC AFTER DASH REPLACEMENT. *SLC
Component Description:5.INTERIOR SYSTEMS[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]ASSIVE RESTRAINT:AIR BAG NHTSA Number: SB627350
Bulletin Number: 011201
Bulletin Date: DEC 2001
Summary:SUBJECT REGARDING FAULTY SAFETY RESTRAINT SYSTEM UNIT CAUSES SAFETY RESTRAIN SUBJECT REGARDING THE FRONT WINDOWS NOT FULLY ROLLING DOWN. *SLC SUBJECT REGARDING MULTIPLE SAFETY RESTRAIN SYSTEM DIAGNOSTIC CODES AFTER DASHBOARD REPLACEMENT. *SLC SYSTEM DIAGNOSTIC CODE 7-3. *SLC
Component Description:6.POWER TRAIN:CLUTCH ASSEMBLY[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]EDAL NHTSA Number: SB629094
Bulletin Number: 02002
Summary:SUBJECT REGARDING A SQUEAK OR TWANG CONDITION WHEN THE CLUTCH PEDAL IS PRESSED. *TT
Component Description:7.INTERIOR SYSTEMS:SEAT TRACK ANCHORS AND SEATS[IMG]i/expressions/face-icon-small-blush.gif[/IMG]THER PART NHTSA Number: SB629383
Bulletin Number: 02009
Bulletin Date: FEB 2002
Summary:SUBJECT REGARDING REAR SEAT-BACK LOCK IS HARD TO TURN.*YD *YD
Component Description:8.ELECTRICAL SYSTEM:IGNITION:ELECTRONIC CONTROL UNIT NHTSA Number: SB629521
Bulletin Number: 02011
Summary:SUBJECT REGARDING ELECTRONIC CONTROL MODULE/POWERTRAIN CONTROL MODULE SOFTWARE UPDATE. *SLC
Component Description:9.INTERIOR SYSTEMS:INSTRUMENT PANEL:GAUGE:INDICATOR NHTSA Number: SB630799
Bulletin Number: 030802
Summary:INFORMATION ON VEHICLES EXHIBITING MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P1457, SLOW RESPONSE OF THE FUEL VENT MODULE. *TT
Component Description:10.VISUAL SYSTEMS:GLASS:WINDSHIELD NHTSA Number: SB627277
Bulletin Number: 061201
Summary:SUBJECT REGARDING CANADIAN BUILT VEHICLES WITH LOOSE OR DEFORMED WINDSHIELD MOLDINGS. *SLC
Component Description:11.ENGINE NHTSA Number: SB626767
Bulletin Number: 1001
Bulletin Date: OCT 2001
Summary:SUBJECT REGARDING VEHICLES WITH TYPE II IMMOBILIZER SYSTEM, STARTER MOTOR WILL CRANK BUT THE ENGINE WILL NOT START. *SLC
Component Description:12.FUEL:CARBURETOR:UNKNOWN TYPE:CLEANER NHTSA Number: SB626769
Bulletin Number: 121001
Summary:INFORMATION REGARDING A SUPPORT RIB INSIDE THE AIR CLEANER CASE WHICH MAY BREAK OFF DURING THE MANUFACTURING PROCESS. *JB
Component Description:13.BRAKES:HYDRAULIC:SHOEISC BRAKE SYSTEM NHTSA Number: SB626674
Bulletin Number: 161001
Summary:INFORMATION REGARDING FRONT BRAKE GROAN/SQUEAL. *YH
Component Description:14.VISUAL SYSTEMS:GLASS:WINDSHIELD NHTSA Number: SB626772
Bulletin Number: 291001
Summary:SUBJECT PERTAINING TO LOOSE OR DEFORMED UPPER WINDSHIELD MOLDINGS. *JB
Component Description:15.ENGINE NHTSA Number: SB631027
Bulletin Number: 302
Summary:CUSTOMERS MAY COMPLAIN OF A BRIEF HESITATION WHEN ACCELERATING AT HIGH ENGINE SPEEDS. *TT
Component Description:16.SUSPENSION:INDEPENDENT FRONT NHTSA Number: SB629541
Bulletin Number: 5905
Summary:CUSTOMERS MAY COMPLAIN OF A TWANG NOISE FROM THE FRONT SUSPENSION THAT SOUNDS LIKE A SPRING CONTACT. *SLC
Component Description:17.INTERIOR SYSTEMS[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]ASSIVE RESTRAINT:AIR BAG NHTSA Number: SB626810
Bulletin Number: 901
Bulletin Date: SEP 2001
Summary:INFORMATION ON SUPPLEMENTAL RESTRAINT SYSTEM LIGHT ON, AFTER OCCUPANT POSITON DETECTION CONTROL UNIT WAS REPLACED. *JB
Old Jul 3, 2002
djmota's Avatar
the defrost/w AC thing is interesting is this a real problem...i always thought that that is just the way they are.
Old Jul 3, 2002
djmota's Avatar
oh ya.. how bout a site on where these were found.
Old Jul 3, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
Quote
[hr]Originally posted by: djmota
the defrost/w AC thing is interesting is this a real problem...i always thought that that is just the way they are.[hr]
Where do you see a TSB for the defrost AC thing? But anyways, this is how they are supposed to be: AC comes on when you turn the vent dial to front windshield. But you can turn that feature off manually. It's the the DIY section of this site.
Old Jul 3, 2002
nihao4587's Avatar
either NHTSA or edmunds.com...maybe other sites as well. good luck
Old Jul 5, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
hmm i think that this is a problem with my car also i gotta get that checked out next time i get an oil change because i knew it was a problem gotta get that dealt with b4 winter time dont want in there getting rusted out for sure.
alaga
25
Aug 13, 2015 04:42 PM
barryaz1
Jul 30, 2015 10:50 AM
viperGTS
Jul 27, 2015 08:40 PM
estes53
Jul 20, 2015 10:43 PM
Ariah J. Davis
Jul 20, 2015 07:15 AM
