Hot day, now my gauge needles are stuck :(
Old Jun 18, 2002
thx1138's Avatar
thx1138 is an unknown quantity at this point
Yep. We've had 2 hot days over here (well over 30 degrees Celcius, that's what we call hot, but some are just warming up at those temp), and when I drove home from work today, my speed dial needle get's stuck between 0 and 60Mph. I have AC Reverse Indiglos. Now on the highway, I keep it at 80-90mph, but it's kinda difficult to do that in the city. I keep hitting the cluster for it to come loose
The Indiglos have been on for only a few weeks. Guess I didn't use enough double sided tape and the heat probably screwed things up. Back to the drawing board I guess. It's cooler now, so I'll see what happens tomorrow morning.
Old Jun 18, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
thats not it it gets over 115 in cali in the summer and that never happens
Old Jun 18, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
You didn't stick the reverse indiglo gauge faces down well enough. just take your cluster out and make sure that the gauge faces lie nice and flat. Test it by holding the cluster as it would lay in the car and gently move the needles up and let it go. If it falls nice and easy, you're set. If not, you'll know where you need to recheck the gauges. I had the same problem. Second time was a charm.
Old Jun 19, 2002
thx1138's Avatar
When I was installing them I didn't use the double sided tape, and noticed right away that the speed dial would get stuck. The face is slightly bulging. So I just figured you really need to use the tape, so I did. After that they worked fine for a few weeks, until yesterday. It's gotta be the heat. When I got in my car I could barely touch my gear *** and even me sunglasses from the glove compartment were really hot.
I just arrived here at work and even though it's cooler now, the problem is still there. So I'm gonna have to take them out and check. If this problem keeps returning I'm gonnna move to Alaska [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Jun 19, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Hmm..the heat here hasnt affected mine yet, but yeah, just crack em open and tape em up again. Should be a piece of cake opening them up the 2nd time around.
-Kre
Old Jun 20, 2002
thx1138's Avatar
Yeah that did the job. Opened them up and just pressed down on the part where I put some tape. It seems fine now, but I don't know for how long. I managed to open the whole thing up in about 5 to 10 minutes. If I keep this up I can do a 4 shock Koni replacement in under 30 minutes [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jun 23, 2002
skitzo's Avatar
skitzo is an unknown quantity at this point
dont use discount swap meet doublesided tape, spend the extra .07 cents and get the scotch brand stuff.
Old Jun 24, 2002
HippyCivicEX012's Avatar
HippyCivicEX012 is an unknown quantity at this point
NJ has had some hot muggy days no probs like that
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
werdnahall
May 17, 2015 11:37 AM
jc33312
May 12, 2015 03:17 PM
manicEL
Dec 10, 2001 06:33 PM
meels808
Nov 15, 2001 07:16 AM
