Warning : Your battery is about to die!
Old Apr 25, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
This is following up to my Door Lock Noise thread. Check it if you want some back ground.
Basics - Brand new car as of Oct 2001. Disconnected battery to work on car about 3 weeks ago. Battery somehow died. Friend jumped car. Got battery checked at AutoZone next day and was told it was fine.
So I wax my car last night. Started it once to move it into my driveway. Car has passive alarm arming, so out of habit, I disarm every time I open door to get towel, wax, etc. This is done like 5-10 times. I start my car again halfway through waxing. Someone moved their car in driveway so I backed out some more to have room. Noticed the door lock noise again this time and the engine stained a tiny bit when I started her up the 2nd time. Disregarded and finished up waxing. Like an hour later, I was done with everything and was gonna head over to friend's place. Battery died again! Was no where near the battery. Didnt even so much as open the trunk. Anyone have an ideas whats going on?
The Warning - If you hear a prolonged door lock pulse and the engine strains while starting..be ready to have someone help you jump your car.
-Kre
Old Apr 26, 2002
Krepoort's Avatar
TTT
Anyone have any idea what could be going on?
-Kre
Old Apr 26, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
Sounds like it may be a problem with how your alarm is hooked up ... is it OEM alarm or aftermarket? May also be how you re-hooked your battery after you disconnected it. I would definitely ask a mechanic to check it out ... ask him to test the battery's charge and fluid, and check also that the alternator is charging your battery properly.
EDIT: oops, just saw that you already got someone to check your battery. Ok, it definitely sounds like your alarm (or power lock motor) is draining your battery. Take it back to the alarm installer (or dealer if it's OEM).
Old Apr 26, 2002
Krepoort's Avatar
Its OEM alarm. KevinFWB actually asked me that on my Door Lock thread. [IMG]i/expressions/face-icon-small-wink.gif[/IMG] Could using the power locks several times actually drain your battery? [IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
-Kre
Old Apr 27, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Bottom line... OEM batteries suck. I'd replace it after 5k miles.
Old Apr 29, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
<< Bottom line... OEM batteries suck. I'd replace it after 5k miles. >>
it aint just the battery, ive put massive drains on that badboy with my system w/car off and its still kickin good.
Old Apr 30, 2002
insan's Avatar
insan is an unknown quantity at this point
i have no idea what u guys are talking about. i can crank the radio up and leave the doors open and have my neons in my grill on for a hour or so and it still starts right up. i think some of you just got lemons for batters.
Old Apr 30, 2002
Mbow's Avatar
Sounds like you probably have a bad battery. Unlocking the doors a hundred times shouldn't cause any problem. Just take it to honda and let them check it out.
Old Apr 30, 2002
Krepoort's Avatar
Done. Battery replaced with warrenty.
-Kre
Uan
Aug 23, 2015 03:03 AM
jnissen
Aug 9, 2015 05:34 PM
jzhartman
22
Jul 23, 2015 10:42 PM
Smokahontas123
Jul 22, 2015 10:07 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
