how do u know when brakes should be changed
Old May 29, 2002
takadadojo's Avatar
takadadojo is an unknown quantity at this point
Ok i know their is a way u can see if ur brake pads r worn from looking inside the wheel.s but i do not know how, do u guys check the mileage and can tell when the brake pads should be changed from their, Anyways, i'm only at 4,500 miles, so my car is pretty new still but i don't want to get
ed over and wear my brake pads out and destroy my rotors.
Old May 29, 2002
RichardCranium's Avatar
RichardCranium is an unknown quantity at this point
You'll hear them start squeaking. There a metal piece on the pad that rubs on the rotor it gets real loud. You can't miss it you'll know it when you hear it. I would'nt worry untill you have atleast 30,000 miles, unless you deliver mail in your car[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old May 30, 2002
mattskav's Avatar
mattskav is an unknown quantity at this point
a) you hear constant grinding
b) you hear a squeeking (first when you turn only, then steadily)
c) your steering wheel + car vibrates when you apply the brakes (warped rotors - do rotors & pads)
the earliest you will likely have to do your front brakes is around 30,000 miles - the latest being around 65,000 miles.
the back brakes will likely NEVER need to be done, they are good for 100-200,000 miles.
Old Jun 4, 2002
03Eclipse's Avatar
03Eclipse should not be trusted03Eclipse should not be trusted03Eclipse should not be trusted
when you can't stop anymore................
GolNat
Suspension DIY
May 12, 2022 06:49 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
mrohitredd
May 28, 2015 10:03 AM
CapYoda
Jan 7, 2002 03:20 PM
02Si
Dec 14, 2001 10:26 AM
