I HAVE NO LOWBEAMS HELP!!!!
Old Jun 14, 2002
OverTheTop's Avatar
OverTheTop is an unknown quantity at this point
Ok so last weekend I went out to go out at about 11pm but much to my suprise I had no headlights. All the other lights worked fine so I checked the fuses but they were fine. I pulled the bulbs out which are HyperWhites and thought maybe they both burned out at the same time but both bulbs looked fine. I checked the wires and they are all ok so I desided to put the stock bulbs back it, still nothing. So here I sit with no lights, well I flipped the highbeams and they work fine. So I didnt know what to do. I have only 300 miles before my warrenty is up so the following monday I took it to the Honda dealer they had the car all day and then they called me and told me that they would not cover it cause I cut the wires. I told them it had nothing to do with the headlights and that I didnt cot the wires. So I went to the shop and showed them that I in know way messed with the wires. Then they tell me that because I opened the headlight housing and drilled strobes into the housing that I voided the warrenty. I was so pissed. So here I sit with no lowbeams and need to get them fix, if anyone can help please IM me at Oakleyoverthetop or email me at CivicSedan@aol.com. Thanks
Old Jun 14, 2002
2k12rsx's Avatar
2k12rsx is an unknown quantity at this point
Hey Over,
I had a similar problem about 2 weeks ago. I went to walmart to get something for my PS2 and on the way back I noticed my
left headlight had burned out. I was pissed because I had just bought my hyperwhite bulbs less than 2 months before.
The next night while driving the other burned out. While shifting, puting on my seatbelt, and turning a small corner in a
residential I accidently turned on my brights. To my amazement they worked yet the low beams didn't. I checked all the fuses
the wires and such and nothing was wrong so I put my stock bulbs in and they worked fine on both low and high. I took
a look at my hyper bulbs and they appeared fine inside. No burning, no broken wires, nothing that I could see. I tried taking
them back to Custom Images and of course they wouldn't take them back. They said to go through the manufacturer but
all the writing on the damn box they came in was Japanese. I told them this and they said it was my problem and offered to
sell me new bulbs. I told the guy "yeah right" and haven't been back since.
Old Jun 14, 2002
OverTheTop's Avatar
But did you try the stock bulbs?
Old Jun 16, 2002
Macko's Avatar
Macko is an unknown quantity at this point
Are those hyperwhites certified? cause if they are the cheap stuff... the lowbeam element is on too long and burns (cause the lowbeams are used more that's why your highbeams are okay)...test out your stock bulbs to see if it's normal
this is why there is such a big difference between teh cheap stuff anf the good stuff
Old Jun 16, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
got a voltmeter? it's what you really need. you might want to check the relay and then the switch
Old Jun 16, 2002
iamfob's Avatar
iamfob is an unknown quantity at this point
bring your car (with original bulbs) to the dealer and ask them to do a warranty repair/checkup
AlbaSurf
May 29, 2012 05:21 PM
datboyjae
Oct 9, 2009 08:11 AM
sl33pyriceboi
22
Oct 7, 2008 09:28 PM
BoSS
Feb 21, 2007 08:59 PM
silverem2
Lighting
Jun 17, 2004 10:18 AM
