Auto tranny question
Old Apr 21, 2002
2k2civic's Avatar
I have a 2002 Civic LX coupe and I notice that if I slow to about 5 mph and then hit the gas again, the tranny kinda jerks, as if doing a neutral drop. I never have done or do neutral drops in my car so thats not the problem. Is this normal?
Old Apr 21, 2002
SpacemanBob's Avatar
SpacemanBob is an unknown quantity at this point
my car does this too, but i dunno if it's normal.
It's the same kind of shake that occurs in a manual drive car if you're in, say 2nd gear, and you take your foot all the way off the accelerator, and then put it back on the accelerator and start to accelerate, all without touching the clutch.
Old Apr 21, 2002
2k2civic's Avatar
Anyone have any info on this?
Old Apr 21, 2002
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
mine does that too sometimes.. im starting to get worried
Old Apr 22, 2002
chinkd's Avatar
chinkd is an unknown quantity at this point
mine too?
Old Apr 22, 2002
opticalvetc's Avatar
opticalvetc is an unknown quantity at this point
yeah Civic Si does it too. its like when you slow down its stuck in 2nd and if you press the gas it quickly lurches into 1st. its anoying because it seems like you have to come to a complete stop to get the tranny to shift back into 1st otherwise you get that damn lurch. i know its going to damaged the tranny overtime. i keep taking it back to honda for some many other things. 1st all the turn signal bulbs burnt out on the right side for no reason, then the a/c stop blowing cold air, then the front suspension was clunking when going over speed bumps, now the tranny is starting to mess itself. its only got 10k on it. i'm running in circles with this car. maybe its time to move on.
Old Apr 22, 2002
MyOtherRideIsBritney's Avatar
MyOtherRideIsBritney is an unknown quantity at this point
I know what you mean...if you are treating your tranny right, you shouldn't have anything to worry about.
I have a 2k2 EX and I think I know what you are talking about. The autos in the 7th gens are just weird...with grade logic being jerky, and this now...
She's so lucky
She's a star
Old Apr 24, 2002
accord94lx's Avatar
accord94lx is an unknown quantity at this point
If you have an automatic change your tranny fluid every 10,000miles!!!! Go take it to honda and have them do a tranny service on it where they change the fluid and filter! Also Honda Tranny's generally shift rougher then others, beleave it or not harder and more abrupt shifts are easier on your tranny then long smooth shifts due to friction and heat. Tranny's hate heat, if you race your auto get a cheap $30 tranny cooler and help your tranny out. my 94 accord lx auto did the same thing your cars are doing and its nothing, just drive it, its the joys of a automatic, I dont know about the civic's but with my accord I just shifted the shifter to 2nd which held 2nd gear in my car and hit the gas and smoothly accelerated then put it back in d4 when I got up to speed. Honda trannys like to be manually shifted even look in your manual it will tell you manually shifting is fine on your auto , just DONT DOWNSHIFT! Upshifting is fine , but downshifting auto's will kill them and allways change your fluid ontime!
Auto = Every 10,000miles
Manual = Every 60,000miles *make sure clutch slave fluid is full allways*
Oil = Every 3,000miles
Coolant = Every Year
Old Apr 24, 2002
nycivic's Avatar
nycivic is an unknown quantity at this point
I don't think it has anything to do with abusing your transmission. I never race this fuçker...because it always loses anyhow. BTW-who races these cars? They barely stay under 9 secs 0-60? Just silly if you ask me. I had my tranny fluid changed at 7500/mi. That didn't solve the problem for me. It's been there since day one. I experienced the problem on my 98 CIVIC too, I thought it was just the nature of the beast when dealing with a low power 4 cylinder POS like this. It's a real irritating thing to have happen though and just another reason why this car won't be in my driveway for too much longer.
Old Apr 25, 2002
2k2civic's Avatar
<< If you have an automatic change your tranny fluid every 10,000miles!!!! >>
I only have 5000 miles on mine.....actually 5008.
Old May 30, 2002
B's Avatar
B
B is an unknown quantity at this point
i have a 2001 ex auto and my car did that...problem is at 16k miles my tranny blew up...not a bad way to spend 4 g's
Old Jun 7, 2002
2001LX's Avatar
2001LX is an unknown quantity at this point
mine does the same thing... it's like the transmission is shifting between 1st and 2nd back and forth.
Old Jun 8, 2002
ALLcustom2k1's Avatar
ALLcustom2k1 is an unknown quantity at this point
Quote
[hr]Originally posted by: opticalvetc
yeah Civic Si does it too. its like when you slow down its stuck in 2nd and if you press the gas it quickly lurches into 1st. its anoying because it seems like you have to come to a complete stop to get the tranny to shift back into 1st otherwise you get that damn lurch. i know its going to damaged the tranny overtime. i keep taking it back to honda for some many other things. 1st all the turn signal bulbs burnt out on the right side for no reason, then the a/c stop blowing cold air, then the front suspension was clunking when going over speed bumps, now the tranny is starting to mess itself. its only got 10k on it. i'm running in circles with this car. maybe its time to move on.[hr]
well, you could try to call it a lemon and get a new one if you are in a good state with cool lemon laws... i know in fl, there is a certain number of times they can try to fix something, then after that they legally have to take it off your hands and trade it for a brand new one with no addt'l fees. But I know in FL, it has to be the same problem repetitively, hope that helps
Old Jun 9, 2002
RON's Avatar
RON
RON is an unknown quantity at this point
What you are discribing is a honda thing , it is the nature of the beast they all do it there is nothing wrong, just drive it and forget it. How can a dealer fix something that is not broke?
Old Jun 10, 2002
civicpimpin01's Avatar
civicpimpin01 is an unknown quantity at this point
Damn, I need to go and change my tranny fluid. I am at 18,000 miles.
Old Jun 10, 2002
Boosted's Avatar
Boosted is an unknown quantity at this point
Actually, there is nothing wrong with your tranny. Unlike a manual, you computer is in charge of shift points instead of you.
This is how it works. When you car drops below a certian RPM or you hit WOT, and you comp knows that it can drop a gear to take the stress off of the motor, then it drops a gear untill a suitable speed and gear have been found to match your driving style. Example, you are going up a hill doing 50 mph at 15 % throttle and you decide that you want to go a little faster, then when you press the accelerator pedal and open your throttle more than 75%, then you car will drop a gear to compensate for the extra stress that is being placed on the motor, specifically the crankshaft. This in return gives the driver a good firm shift which seems to almost be a jerking motion. The harder the shift the better, this is not always true. Honda has found a real sweet shift time for the auto's.
Here is how the ECU shifts your car at WOT if you are in D.
0-40 mph = 2
41-80 mph = D3
81 and up = D
This is the matrix that the ECU goes by for maxium MPH shift points.
TIA
Boosted
Burnout
Jul 15, 2022 10:24 PM
civic__duty
24
Jun 11, 2015 12:29 PM
MajTom
Jun 2, 2015 11:48 AM
dosmastr
May 5, 2015 12:19 PM
viper775
Dec 9, 2001 10:52 PM
