MAJOR PROBLEM PLEASE HELP ME ASAP!!!!!!!!!!!
Old Dec 3, 2002
MOUSE's Avatar
MOUSE is an unknown quantity at this point
major problem please help asap
i was driving today and my car started squeling when i would push down on the gas. then all of the sudden i heard something break under the hood and then the squeling stopped and i had no more air conditioner .i looked to see if it was the belt but it is still there. what could of happen. i just hit 36000 mioles yesterday please help me now thanks mike [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Dec 3, 2002
solar's Avatar
solar is an unknown quantity at this point
Are you sure you didn't break a belt? Because we have 2 on our cars. When you said you had no A/C did you mean that it was still blowing out the vents but it was warm or did you mean that the vent fan stopped. Remember that the A/C compressor is down under everything else so make sure the belt isn't missing, if its not missing, reply with a little more info.
Old Dec 3, 2002
MOUSE's Avatar
it looked like both the belts were in place when i looked but the a/c was not blowing cold just air was coming out so what could it be thanks
Old Dec 3, 2002
solar's Avatar
Okay if the belts are in place than most likely the compressor locked up and one or 2 things happened, after the compresser locked up it possible you blew the fuse to the compresser clutch which would disingage it, or you had a rapid r-134a (refrigerant) loss which would cause the compressor to freeeze up and the low pressure switch kicked in and disengage the clutch. Have the A/C checked out at a local shop or dealer, but I guess you're not under warrenty anymore so a local shop would be best. A local shop should be able to tell you pretty quickly what went wrong, good luck and let me know how it turns out.
Old Dec 3, 2002
MOUSE's Avatar
but what was the squeling and why did i hear something break .
Old Dec 3, 2002
solar's Avatar
Quote
[hr]Originally posted by: MOUSE
but what was the squeling and why did i hear something break .[hr]
Well the squeeling came from the belt driving the compressor, when the compressor locked up the belt starting slipping around the pulley. The break could have been a A/C line breaking letting all your r-134a excape, a A/C line will make a loud pop when they break under presure, which would cause the commpressor to lock up and the squeeling belt. Unless I could look at it this is just a educated guess, but I think I'm on the right track.
Old Dec 3, 2002
MOUSE's Avatar
but after i herd the squeling the i pushed on the gas and then the squeling got louder and the i herd something break and then the squeling stoped but i did not see any broken a/c line i think the compressor went . how much is it to fix if that is the problem let me know please
Old Dec 3, 2002
solar's Avatar
Well you probably wouldn't see the broken line becasue its probably very small, you need to see if the system is still under pressure, if it is than its not a line. A compressor isn't cheap but should be under $500, but before you do anythiing take it to a local shop and have them look at it just to make sure that what the problem is. If you start swapping out parts without the proper tools and know how, you'll just run into more problems. The problem you explained is much more compicated than what can be addressed in this forum.
After you have someone look at it PM me or reply, because I'm curious. Or if you feel like driving up to Tampa I'll look at it for you.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 8, 2002
TeamOutrage's Avatar
TeamOutrage is an unknown quantity at this point
why cant you be located in cali.....i had the same thing happen to my a/c unit and my warrenty is up too. this is great to know. my a/c does the same thing....blows only hot air. i did not hear any squeal or pop but my music might have been up too much to hear. guess i have to start saving. im really starting to hate this car....too many problems with either my car or the dealer
Old Dec 9, 2002
MOUSE's Avatar
YEA THEY ARE A PIECE OF $HIT
Old Dec 9, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
If you are just out of warranty, you can take it to Honda and see if they will fix it under "good will".
Old Dec 10, 2002
MOUSE's Avatar
YEA IT IS HARD ENOUGH TO GET THEM TO DO WARRNTY WORK LET ALONE GOOD WILL WORK.
Old Dec 11, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Should have bought the extended warranty...mine is warranted for 5 years which is the length of my payments, which is good cause my 36,000 mile one is up soon since I am @ 30,000 now...not to mention the extended warranty boosts the resale value of your car if you keep the documentation and paperwork to prove it...
2Hottie
Jon-Ohio
Jun 30, 2018 08:10 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
lapchern
Bolt-on Engine Performance
Dec 22, 2001 06:23 PM
