... and also, anyone have a squeaky clutch pedal?
after about 2 months, my clutch pedal has started to squeak/creak when it's being released (after being pressed down completely). it's REALLY ANNOYING as you might imagine, hearing this loud SQUUEEAAAKKK!! every time you shift. i think it started b/c i had been pressing the clutch too hard to the floor for a couple weeks. but still, it seems kind of retarded. has anyone experienced this sort of thing and can it be fixed (with some grease or if it's not the pedal squeaking i might be stuck with it forever)?? thanks for any input.
Mine's done it since 1200 miles, I have 16000 on the car now and i CHANGED my clutch. It's probably something with the pedal/linkage, doesn't hurt anything, it's just annoying. Some lubrication somewhere should fix it but I have been too lazy to check it out
Quote
[hr]Originally posted by: Mbow
Yep, I had the same problem. I just sprayed some wd-40 on the parts that were making the noise. That was over a month ago and it hasn't come back.[hr]
[IMG]i/expressions/face-icon-small-tongue.gif[/IMG][IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Quote
[hr]Originally posted by: impetigo
that sounds worth a try, not really sure which part exactly is making the noise. did you just kind of spray the pedal as far down as you could or did you actually take stuff apart? i tried moving my seat further back so i would put less pressure on the clutch, and that seems to have helped. only squeaks occasionally now, but i gotta get some WD40...
[IMG]i/expressions/face-icon-small-tongue.gif[/IMG][IMG]i/expressions/face-icon-small-tongue.gif[/IMG][hr]
Quote
You'll understand what I am talking about when you look under there.
I have it off and on. When it's cold it does it, but if it's warm out, it's fine. I think it's just something in the pedal mounting, so I'm just gonna leave it.
I had that problem with my clutch ....just get down there and press the pedal with ur hand all the way in and put some wd 40 or something on it and let it up slowly while u do that that'll do the trick
Mouhahaahah
Had the same problem with my clutch pedal and was searching if anyone had the same problem =))))
I haven't hear it before my girl friend told me....what is this little sound ? ? ? [IMG]i/expressions/face-icon-small-smile.gif[/IMG] mouhahaah the clutch pedal that is making some noise....
I've put some WD-40 and the problem is solved!
Eric
Eric
JetsterDajet
Aug 15, 2015 08:07 AM
alaga
25
Aug 13, 2015 04:42 PM
