starting the car when the car is already started?
Old Nov 14, 2002
civicman10's Avatar
civicman10 is an unknown quantity at this point
Confusing huh? Well I was pulling into a parking spot and put the car in neutral and left the car on while i was sitting in it (i was waiting for someone). I was listening to music so i was kind of tuning everything else out. Anyway my friend got in the car and I started turning the key. It made this really strange sound, almost as bad as grinding your gears. I did it like 3 consecutive times before i realized that the car was already on (damn our engines are quiet). Has anybody else done this? I was a little worried afterward because i did it 3 times. Let me know whats going on please. thanks
Old Nov 14, 2002
blackbullet's Avatar
The Legend
I've never done it in my car, but on accident in other peoples car. I'm sure it would do harm if you did it everyday, but doubt it did major damage this time.
Old Nov 15, 2002
2001CIVICLX's Avatar
2001CIVICLX is an unknown quantity at this point
It shouldn't cause any problems doing it a couple times, just don't go doing it everyday...
Old Nov 15, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
I agree, common sense says that if you do something like that every day, you are bound to have a problem real fast! But once or twice isn't so bad..our cars are really quiet so it makes it hard to hear them idling...
2Hottie
Old Nov 15, 2002
flotsamm's Avatar
When you do that your grinding the starter on the flywheel. If you do this often you could possibly snap off a couple of teeth from the flywheel or damage the starter. Either way its alot of $$$ and probably not covered under warranty, unless you DIY.
Old Nov 15, 2002
CarbonFly's Avatar
I did it a couple of times when I first started learning how to drive stick on my civic. I thought that I had stalled out my car and went to start it back up, it made that grind sound. Then I realized I had pushed the clutch in fast enough to keep the engine running.
Old Nov 16, 2002
Shoot, even the Service Manager at the Honda Dealership did it when we were taking it out for a test drive for a problem with the tires...I nearly crapped my pants when SCCCCCRRAAATTCCCHHHH!!!!
CarStuff
Dec 6, 2020 12:52 PM
McD
Apr 29, 2015 03:50 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
SSMatey
Apr 13, 2015 06:09 PM
Ramen
Canada West
Nov 5, 2001 06:07 PM
