auto down window stops!?!
Old Dec 11, 2002
2k2EXCOUPE's Avatar
TUCKIN 19s
This has down it a few times, i press auto-down and it just stop like 1/4 thru. I press auto down again and it goes to 1/2. and then i press it AGAIN and it goes to 3/4. and then it finally goes down all the way? ive also noticed it usually does this more in the cold then the warmer weather. it doesnt do this too much but still enough to annoy me. any suggestions or ideas?
Thanks
Old Dec 12, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
this started happening to me about 4 months ago. it has been covered on the site, because I remember doing a few searches to look into it. just take it to your honda dealer to fix. I forget what causes it, and i don't care really. I only used the feature twice before it broke.
Old Feb 7, 2003
PiCASSO's Avatar
PiCASSO is an unknown quantity at this point
Did any of you boys get the windows fixed? My apperantly seems to go down 1/3 down on the first pull ONLY when I'm nearing my apartments garage door card reader. I can re-create that nearly 90% of the time. Yet, if I try to do it elsewhere, it won't work. I'll bring it to the dealership, once I know that I can recreate the problem in front of them.
Old Feb 10, 2003
solar's Avatar
solar is an unknown quantity at this point
I've been told that the window motor stops the window travel when the motor sences a power drag, so I've been told, you need a squirt of silicon spray in the window track, this will let the window go down with less resistance. (Don't use WD-40 or CRC, just use silicon)
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
civic__duty
24
Jun 11, 2015 12:29 PM
tylerginevan
Apr 27, 2015 12:29 PM
mwwhonda
Nov 7, 2001 07:24 PM
