Check Engine Light & TPS
Old Nov 15, 2002
Blown's Avatar
Blown is an unknown quantity at this point
Has anyone have their check engine light come on and then it's followed by an increase in your idle? I have, my light came on and then my idle went up to 1500rpm a day later. I took it in to Honda to fix and the code that triggered the light was from the TPS(throttle position sensor). They said they re-adjusted the sensor and cleared the codes. Well, when I picked up my car, the light was still on and my idle was still too high. So, I scheduled another appointment about a week later. The day before the appoinment, everything went normal so the service guy told me not to bring it in. Has anyone else ran into this problem? My invoice lists that my "aftermarket filter could be the potential cause but requires further investigation".
Old Nov 15, 2002
flotsamm's Avatar
Maybe try putting on the stock air filter assembly if you still have it, for testing purposes only.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
