Injen CAI --A/C Keeps coming on when I try to turn on defroster???
Old Oct 30, 2002
HondaCivicEX2002's Avatar
HondaCivicEX2002 is an unknown quantity at this point
I am sure I am missing something very simple, But every since I installed my Injen CAI. Every time I try to turn on the defroster my A/C comes on???
Whats the problem?? I tried tighting down the crappy bolt injen gives you to bolt down the pipe, I even put a locker washer on it to keep it in place. I also tried the original bolt and grounding that bolt to a good ground. No luck.
Does anyone out there know what I need to do to fix this problem?? So my A/c don't come on, when i try to use the defroster, its cold enough outside don't need any extra cold air.
[IMG]i/expressions/face-icon-small-mad.gif[/IMG][IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Oct 31, 2002
zetaR's Avatar
zetaR is an unknown quantity at this point
The A/C is supposed to come on when you turn the defroster on. It has nothing to do with the intake. I would advised sitting and down and reading your manual. It specifically states in their that the a/c kicks on when the defroster is being used. However, if you must turn it off, go to the DIY part of this site. I believe there is a DIY for turning off the a/c while the defrost is on.
Old Oct 31, 2002
azn2k1civic's Avatar
azn2k1civic is an unknown quantity at this point
if you turn the **** to warm/hot air instead of cold, that would help.
Old Oct 31, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
DIY: Shutting off A/C during defroster
Old Nov 2, 2002
Apreciate it, thanks a bunch.
I only have 200 miles on my car. I have more modifications then gas station stops. I thought it was the injen. didn't realize it did that stock.
:_ bow:Thank you
trevor
Nov 15, 2001 05:59 PM
se7en
Nov 12, 2001 10:13 AM
Maxdogs
Bolt-on Engine Performance
Nov 11, 2001 07:50 PM
Daniel420
Nov 9, 2001 08:36 PM
NoToRiOuSxPiNoY
Nov 7, 2001 11:19 PM
