Any one know how to reset the ABS light! Please help
Old Nov 21, 2002
Willy's Avatar
Willy is an unknown quantity at this point
I jacked my car up the other day and took the wheel off and put it back on.And when i went to start it the abs light was on and it didnot go off.Its done this to me before and finally it went off ,but i dont know about this time. does any one else have this problem? how can i fix it with out taking it to the shop. please help![IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Nov 23, 2002
1955's Avatar
which wheel did u take off and for what reason,need to know b4 i can help
Old Nov 27, 2002
Willy's Avatar
I took the left rear wheel off the car And put it back on and the light came on. Whats up with that? If you have any ideas please let me know it has been 5 days since it came on,and it still has not went off.
Old Nov 27, 2002
1955's Avatar
check the ABS sensor wire ,its clipped on the lower control arm,the same location for a camber kit.if the wire is ok then its beyond my knowlege,next possible cause is the fuse for the ABS,according to my shop manual.
Old Nov 27, 2002
Willy's Avatar
Which fuse is it. Where is it located? thanks
Old Nov 28, 2002
matt007's Avatar
matt007 is an unknown quantity at this point
you could have messed up the speed sensor for that wheel, or the wire. Take your wheel back off and look to see if any thing looks weird or not normal. I did this with my Ford Expedition I had. The sensor was pushed back so I rebent the mounting braket for it. Hope that helps.
Old Nov 28, 2002
Willy's Avatar
Thanks ill try that to.
Old Dec 3, 2002
cim's Avatar
cim
cim is an unknown quantity at this point
The ABS indicator light is staying on to indicate a failure in the ABS unit. Most likely the speed sensor on the wheel to which you were working on.
Certain ABS codes are required to be stored in non-volatile memory thus they will never be cleared EVEN if the battery is disconnected for a long duration. This is required for safety purposes.
I would recommend that you get the DTC code retreived before attempting to clear ABS codes as proper operation is critical to safety. This can be done with a honda PGM tester or by shorting the SCS connector on the OBD-II connector to ground and observing the blink rate of the ABS indicator light.
Anyways, there are two ways to clear ABS codes: 1) with the honda tester or 2) by turning on and off the ignition switch twenty times in a row.
Old Dec 4, 2002
Willy's Avatar
are you talking about where the key goes in the ingnition switch. Just wanting to make sure.thanks for the help[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 4, 2002
Willy's Avatar
are you talking about the ignition switch where the key goes? If so i just tried it and the light is still on.Is there something else i haft to do while turning it on and off?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Dec 4, 2002
solar's Avatar
solar is an unknown quantity at this point
You're going to have to take it to the dealer, the only way to turn the light of is to reset the DTC (Diagnostic Troble Code) and the only way to do that is if you have a Honda PGM Tester module. You can clear the codes by turning the ignition key switch to ON (II) then Off at least 20 times, but if you have a problem; which i think you do, the light will come right back on because the computer is throwing a code back out.
Go to the dealer and get it straightened out because you don't want to screw with the ABS system. Just don't tell the dealer you did any work on the car.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
EDIT:spelling
Old Dec 4, 2002
cim's Avatar
cim
Quote
[hr]Originally posted by: *****
are you talking about the ignition switch where the key goes? If so i just tried it and the light is still on.Is there something else i haft to do while turning it on and off?[IMG]i/expressions/face-icon-small-confused.gif[/IMG][hr]
What solar is saying is correct. If there is a problem still in the system then the DTC will just get set after your reset any error codes and the ABS indicator light will stay on.
Old Dec 5, 2002
Willy's Avatar
my car is heavily modified and i dont want the dealer to void my warrenty[ excuse my spelling]. do you think they will? I may just haft to leave the light on all the time. My car acts fine and runs and brakes the same. I just wish i would not have took that dam wheel off. thanks you guys for the help![IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Dec 6, 2002
solar's Avatar
Quote
my car is heavily modified and i dont want the dealer to void my warrenty[ excuse my spelling]. do you think they will? I may just haft to leave the light on all the time. My car acts fine and runs and brakes the same. I just wish i would not have took that dam wheel off. thanks you guys for the help![IMG]i/expressions/face-icon-small-tongue.gif[/IMG][hr]
I think it was noted on this thread before; unless you modified the brakes the warrenty will not be voided on your car. Just take it to the dealer, I dought any mods you did to the engine messed up your ABS system. Take it to the dealer...........take it to the dealer............take it to the dealer.........
Old Dec 6, 2002
Willy's Avatar
i guess i wil haft to take it to the dealer. now just, today i had another problem my dam battery was dead this morning. it will not hold a charge,i guess it has a dead cell.But my alternater is charging though. thats another 80 bucks! i might as well buy a optima batery ive been wanting one for a while.
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Blazz
May 25, 2015 10:56 PM
dooner24
Apr 14, 2015 07:51 PM
oneqwkfbody
Nov 18, 2001 08:04 PM
