Stock Cd player
Old Dec 10, 2002
XxJDMCivicxX's Avatar
Stock Cd player
My stock cd player doesn't read my cd-r's some brands yes some no and it only seems to happen when it's cold anyone know?
Just realized I posted this in tech when i wanted to post in vehicule issues can a mod plz move this thanks. $700 for nothing
Old Dec 10, 2002
mohawkboom's Avatar
it's not designed to read CD-R's...so some higher quality one;s work....
Also moved for ya
Old Dec 10, 2002
DaveyD's Avatar
Mr. Negative
DaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the rough
I've had no problems with my stock deck and CD-r's, and even in the cold here in MN. I've used Imation, PNY, and now I have Fuji. I pick up whichever ones i can get for cheap. I've heard that it could be because they might have been burned too fast?
Old Dec 10, 2002
CarbonFly's Avatar
I never had any problems reading burned cds.........of course I only played on CD-R in the player as I drove the car off the lot and over to Custom Car Stereo to have them install my deck and soundsystem. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Dec 11, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
You know what I heard from one of my friends about this...he said put a piece of clear tape on the top of the disc...said it had something to do with the weight of the cd or something as stupid as that sounds...
2Hottie
Old Dec 11, 2002
thirdhonda's Avatar
thirdhonda is an unknown quantity at this point
Believe it or not, one of the Civic TSBs has a short statement about this, which means you're not the only one who has noticed this problem. If I recall, Honda basically pointed out that it shouldn't be scratched, and that the recording session had to be "closed." Other than that, you might want to avoid CD-RW discs, and also try experimenting with different brands, and avoid the cheapo, 50 packs of blank discs. In my old Sony cd player, only gold discs with the greenish back would play, but I hear that the silver discs with the bluish back are longer-lasting. It has to do with optics, which I'm no expert on.
Old Dec 11, 2002
Mbow's Avatar
As long as you are burning to cd-r disk only? Cd-rw can create problems.
Are you converting everything to wav files?
Do you use the same prog to convert mp3 to wav everytime?
Do you use the same software to burn everytime?
Are you closing the disk when you burn?
The temperture shouldn't affect what plays and doesn't.
Cd-r disk that have wav files will pretty much play in any cd player out there. If some are working and some aren't, something is different about the ones that don't work. Check the above stuff.
Also, what happens when it doesn't work? Do you get static or does the hu just spit the cd back out.
I used to play my cd-r disk in my car all the time (I have mp3 now) with no problems with many different brands of cd-rs.
Bottom line: It's not the disk itself...
Old Dec 15, 2002
DaCurryman's Avatar
DaCurryman is an unknown quantity at this point
I have the same problem. It's not that it happens all the time. Didnt happen during the summer. But it happens a lot now. It's when I leave a CD in the HU say overnight, and when I come back in the morning when the whole car is cold, it wont read the CD. This happens to me with non CD-Rs too...like regular audio CDs that I buy.
Old Dec 16, 2002
Quote
[hr]Originally posted by: Mbow
Bottom line: It's not the disk itself...[hr]
Only cd-r, not converting to wav, yes same program everytime (nero), not sure if the disk is closed or not think it is though, it doesn't play i just get static and some song extracts like half a second, i've used the following; pine, cursor, memorex, memorex black, fujifilm, verbatin and smart buy most of them don't work. Eventually the cd reads but it takes about 10 minutes and if you skip a song or rewind the cd player will create static again for a long time also around 5 minutes.
Old Dec 16, 2002
Mbow's Avatar
In what format are the files? Mp3, wav, or what?
If you are getting static the hu must be reading something. Otherwise, it wouldn't make any noise at all.
You may want to try a different prog to burn the files.
I use memorex, fuji, and imation. I have never had a problem with the disk playing in ANY cd player. You are using WAV files right?
Where are you getting your music files and in what format are they in when you get them?
Old Dec 17, 2002
the program i use, doesnt make me convert them to .wav it loads them and burns i know it doesnt burn that as actual .mp3 files or else i would be able to fit more than 80 minutes of songs. If i convert to .wav files will that fix this problem ill try it out on the weekend. Got around 150 blank cd-r's sitting around ill test a couple brands out [IMG]i/expressions/laugh2.gif[/IMG]
Old Dec 17, 2002
Sparty's Avatar
Sparty is an unknown quantity at this point
Nero converts during the burning process. You shouldn't need to do anything.
Try using your CD's in other (older) CD players around the house. If they work there, it's gotta be your deck.
Don't ever use CD-RW's. You need a special drive to read rewritables. They WILL NOT work in any normal music cd player.
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
