Weird Almost Vibration sounds comming from Inside Behind Drivers Side
Old Oct 25, 2002
netcbc's Avatar
netcbc is an unknown quantity at this point
I got this weird buzzing sound, i don't know wut it is, its like something vibrating because somethign is loose, its a weird weird sound... can't figure out what it is??
Old Oct 25, 2002
ducksause's Avatar
ducksause is an unknown quantity at this point
do you have a cat-back exhaust system?
If you do that may be cause the buzzing noise...cause that happens to my ride too until a dynamat the floor board.
Old Oct 25, 2002
WeakVTEC's Avatar
WeakVTEC is an unknown quantity at this point
Ack it's happening to me too a buzzing sound that increases with speed and i cant figure out where the damn thing is coming from. Does yours increase with speed as well? I'm going to try inserting my silencer into my muffler tonight and I'll post here if it works.
Old Oct 25, 2002
WeakVTEC's Avatar
Now the dealer says it might be a wheel bearing, from the good ol' FL heat, earliest appointment in Nov 4. hopefully it won't melt and lock up the wheel
Old Oct 26, 2002
netcbc's Avatar
Quote
[hr]Originally posted by: WeakVTEC
Now the dealer says it might be a wheel bearing, from the good ol' FL heat, earliest appointment in Nov 4. hopefully it won't melt and lock up the wheel [hr]
what that bad?......... i only can hear it when the car vibrates alot, which usually happens at 1 - 3 rpm........
Old Oct 26, 2002
WeakVTEC's Avatar
Naw must be different type then, mine's loud at any RPM above 60mph, it's either a wheel bearing or my tire with 3 patches in it is about to discintigrate , gonna throw a full size spare on tomorrow and see what that does
Poopies
Apr 20, 2017 11:36 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
ej8
Apr 13, 2015 06:36 PM
mwwhonda
Nov 7, 2001 07:24 PM
EXWisdom
Nov 5, 2001 10:24 PM
