Torqueing bolts in the cold
Old Feb 6, 2014
mikey1's Avatar
i am doing a timing belt/water pump/tensioner job for a friend, i have done the job many times so its no problem for me to do,
but my concern is the cold weather,
previous timing belt jobs i have always done during warm weather i would say 70F+
i will be doing this job when the outside temps are around 0F, i will be inside a garage but its not insulated and not heated, so not much warmer than the outside temps
i am assuming threads and bolts are alot more fragile at these temps and my concern comes when torqueing down key/large bolts, as an example the timing tensioner bolt,
i am terrified at the possibility of stripping the threads out of the block,
so i guess my question is.....would it be worth while to heat the threads and bolt up a bit before installing the bolt with something like a hair dryer? or is it safe to assemble it in these cold temps as is???
Old Feb 6, 2014
Re: Torqueing bolts in the cold
Never had issues with torquing at different temperatures, nor do I recall ever reading info pertaining to the subject.
However, if you are dealing with a car that uses a locking tensioner, the timing belt tension is greatly affected by engine temp. Tensioning is supposed to be done at room temp (~70*F).
If you are doing a 7th gen, this is irrelevant because the tensioner floats all the time. (Remember, I do not unbolt the tensioner at all on these until it's time to replace it.)
HTH
EdGasket
40
Nov 27, 2015 11:11 AM
carid
Nov 7, 2015 01:46 AM
breanna_17
Jul 21, 2015 04:01 PM
Theshwartz35
Jul 17, 2015 11:13 PM
hoofboy
Jul 17, 2015 04:27 PM
