Clearance on back Arch problem
Old Oct 3, 2013
ArronL93's Avatar
ArronL93 is an unknown quantity at this point
Hello I have a problem with my 2000 EK Civic. I just put 16' alloys on it but the back alloys are wider and there is no clearance what so ever on the back. I was told to maybe roll the arches but im not sure will this give me enough clearance and if i have passengers in the back im back to square so has any one got any ideas?
Edit Report
Old Oct 4, 2013
Fliptard's Avatar
Fliptard will become famous soon enoughFliptard will become famous soon enough
Re: Clearance on back Arch problem
buy a rear camber kit. DO not buy a cheap Aluminum one on ebay that has the threaded end and the end that bolts to the car welded, the can break. There is a steel cheap one ($50ish) on ebay that's made in all one piece. Unless you want to spend more on a Skunk2, BWR or so.
Then bolt them up and camber your wheels in so when the car goes down, your wheels tuck up under the car instead of it sitting on the wheels
cruisers10
May 12, 2015 10:46 PM
crowtoo
May 11, 2015 06:50 PM
tylerginevan
Apr 27, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
Flatlander
Nov 16, 2001 05:38 PM
