2001 ex Head gasket question
I am real slow as other things have come up. Anyway I am getting very close to pulling my head. I have the top timing cover removed and have a question. My timing belt has less than 20 k miles on it. I was going to re use it. Is it necessary to pull the crank pulley or is there a way to get the belt off the cam pulley and get it back on without doing that. Trying to avoid finding the special crank pulley holding tool. If it is better to take it all the way down that is what I will do. Thanks.
Ed
Ed
Re: 2001 ex Head gasket question
I use a hook tool (bent coat hanger) to lift and release the tensioner spring from its upper peg.
Then I can slip the timing belt off the cam gear.
It might be tricky to put it back together, but it's doable.
Ed
You should be able to see in this pic, holes in the intake gasket (#8) to indicate which bolts need to be removed.
You can see the brackets that anchor the bottom of the plastic manifold here too (#11, 12, 13).
10mm bolts pointing straight up, or 12mm bolts holding the brackets to the block.
Oh yeah, once you get this apart, I recommend (assuming yours has EGR) you take the time to remove the injector/EGR plate #7 and clean out all of the carbon buildup from the EGR passages in that plate.
I was able to acquire the manual on cd and had that diagram. It is just a little complicated. I was trying to not pull the entire intake off. Can I take that plate off while everything else is hooked up once I get the head off?
It might be easier to get all the hardware loose while it is still anchored to the cylinder head though.
HTH
Ed
I have everything loose except the center bottom nut.
Having many wrenches in various brands and angles helps to get those hard to reach ones where you don't have hardly any room to swing a wrench.
Pretty sure that one has to come off, if I'm looking at it right. There's a hole for it in the picture of the intake gasket, so there should be a stud sticking out of the head in that spot.
If I am looking at it right there are eight assorted nuts and bolts that hold the intake assembly on. I have all loose except the center nuton the bottom. It is the center one bottom left in the diagram. there are three together in the picture by the long bolt. I trying to get it from underneath like I did the other two. I cant see any other way to get at them. Any tricks?
Ed
Isn't there a gap between the 2 middle intake runners where you can see the offending nut from above?
7th Gen Civic DIY Enthusiast!
That center bottom bolt is a biatch. It's right above the oil pressure sensor and you need a longy wrench with an angle on it. And if you think getting it off is hard, wait until you have to put it back on. It was a painful experience for me.
I'm real sure I do it from above: I remember after removing the upper nut out of the way, getting it broke loose, then using a screwdriver to spin it off. A strong magnet so it doesn't fall down and get lost.
Many different wrenches to find one at the right angle to have room to swing it and get it broke loose.
You can't use the screwdriver to spin the nut off if this is the last fastener holding everything together.
Just loosen the brackets and pull it with the head, yes it is heavy, with all attached, but have a friend help yank it off. I pulled it off with the intake and exhaust manifolds attached.
Ended up pulling the head and the intake together. It really isn't that heavy , just awkward. Easy for two people. If I every do it again that's how I would do it. Spent a day trying to get the intake loose. Anyway progress is made. Now I can get back to work on it. The cylinder that was leaking has no carbon on the piston so I guess it was steam cleaned. I saw a little stain that looks like it was where it was leaking. Can't find my straight edge but I used a carpenters level and head looks ok. Have to check it out better but now a little cleaning and I can start to put it back together. I was a little surprised that once the head bolts were out the head pulled right up. Other engines I have worked on you had to pry it to get it loose. Thanks to everybody to get me to this point. I will post pictures later.
Ed
Ed
Cool. Glad you got it out. I never would've done that, but that's me. I just couldn't see disconnecting the couple hoses, sensors and whatever else when I could just get that one PITA bolt out and zip tie (in my case) the intake back and away from the head and at the same time still have access to the EGR passages to clean them.
Just opened my gasket kit. There are two large conical rings in the kit. One is copper colored and one is like pewter colored. They are shaped like exhaust donuts. Anybody know what they are used for? I think they are for the exhaust flange but I did not take the header apart. There is two of them. The other for a different application? The label on the box on lists one exhaust flange.
Kits are usually compiled to cover several versions. Use what you need.
Got pics of the parts in question?
Ed
Checked the head the best I could but just didn't have confidence in myself. Took it to the local head shop to have them pressure test and resurface. At least I will know it is right. I plan to keep the car for a while so I thought it was the best way. Spent the afternoon pressure washing the engine compartment so everything is nice and clean.
Ed
Ed
Got my head back from the shop this afternoon. It is like brand new. anxious to get it back together. Calling for rain. Do you use any sealer on the head gasket?
Ed
Ed
01civyv3
Jun 2, 2015 05:21 AM
zaboomafoozarg
May 30, 2015 09:21 AM
mrohitredd
May 28, 2015 10:03 AM
HondaHomer
May 14, 2015 12:24 PM
