2003 d17A1 Flywheel help!!! .137" cut - .065 cut
Old Nov 3, 2013
Williamsam21's Avatar
Williamsam21 is an unknown quantity at this point
Need help ASAP! Put in a new clutch lastnight. Took flywheel to get resurfaced. They call me and tell me my flywheel is way off there specs . That it has a .137" cup and specs say it needs to be .065 for a d1.7a1. I didn't think twice clarified my engine and said to cut it to specs. Put it back together and my friction plate is just spinning the cut was way to deep . Car inoperable . Need to find out what flywheel was in it cause they said it should be a thinner one but the one I had worked just fine before they cut it down 3/4 of a inch . Need to find out what flywheel I had
Old Nov 3, 2013
Re: 2003 d17A1 Flywheel help!!! .137" cut - .065 cut
Tranny says b6b and had an Exedy clutch kit before I changed it to one that lined up and matched and fit perfect
burnyd
ECU Fried
May 24, 2018 10:44 PM
JetsterDajet
Aug 16, 2015 01:56 PM
redcloud
25
Aug 12, 2015 01:23 PM
Doug Lassiter
Aug 9, 2015 09:31 PM
jedi
Aug 3, 2015 04:26 PM
