strange noise from the front suspension
Old Jan 8, 2014
mrohitredd's Avatar
mrohitredd is an unknown quantity at this point
Not sure, if my 02 Civic LX is asking for a heated garage in this arctic cold weather !
i heat the car for about 15 mins before i drive in the morning & the 2-3 days when the weather way under 0F, i hear some noise coming out of the suspension. Mostly from the left side. The car (suspension) makes noise while making a turn or if go over a bump or a pothole. Does any kind of oiling helps ? I recently crashed my 2002 Civic & bought this about 15 days ago. So, pretty new with the car & its history. Tha car now has 132k miles...
Old Jan 9, 2014
Stock 99's Avatar
Re: strange noise from the front suspension
Oh the pleasures of an unknown car.....I think I live in the only place in North America right now that isn't cold...just had to rub that in a bit.
So before you bought it you inspected it right?
Could be any of your front suspension parts. Tight turning noise could be CV joints, could be LCA bushings, ball joints, tie rod ends, upper control arm bushings...you should either inspect all of that or have someone do it for you. That being said.....
I had to replace my upper control arms last spring (ball joint/bushing) and every little bump I hit sounded terrible because the upper control arm bushings were shot. I also have this very weird condition in the fall where my lower control arm bushings 'squeak' right around 0C but not above or below that temp. I took them all apart and greased the bushings and it made a big difference but still had some squeaking around 0C. Take a good sized bar (like a big screw driver) and place it under your lower ball joint and see if there's up/down play, same with the tie rod end.
If I had to guess it's probably your upper control arm bushings though and they are easiest to replace yourself as the entire upper control arm which will include the upper ball joint.
Old Jan 9, 2014
mrohitredd's Avatar
Sure... will give it a try...
Old Jan 9, 2014
GolNat's Avatar
Prelude Owner
7th gen civic doesn't have upper control arm in the front, only a lower. If the noise is coming from the front I would suspect the strut mounts. They can make noise while going over bumps and are a common part to go bad with mileage.
I would inspect the ball joint (only lower) for excessive play.
Old Jan 9, 2014
Stock 99's Avatar
Sorry! My bad. I didn't realize 6th gens were so much better designed/engineered/built than 7th gens.
Old Jan 9, 2014
GolNat's Avatar
Prelude Owner
7th gens are equally designed/engineered/built as well...minus head gaskets, strut mounts, and headliners
Old Jan 9, 2014
Stock 99's Avatar
LOL
Old Jan 11, 2014
and sway bar endlinks
Old Jan 19, 2014
mrohitredd's Avatar
Alright guys... it was the Broken LCA Bushing... Replaced the whole Ctrl Arm (Easier) & the car runs quite...
edspyhill09
Jun 12, 2016 02:45 PM
bo_red
Transmission
May 3, 2015 09:14 PM
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
