'03 ringing noise at specific RPM
Had head gasket replaced and now at 3600 rpm's the engine makes a high pitched ringing sound. Occasionally hear it faintly around 1900 rpm, but much louder at 3600. Everything else seems fine and only last a second while transitioning the rpm.
Suggestions?
Thanks!
Suggestions?
Thanks!
Re: '03 ringing noise at specific RPM
See if the heat shield covering the exhaust manifold is loose, probably toward the front and bottom.
It's common for the little bolts to snap off when one tries to remove them.
If that's not it....How would Stevie Wonder locate a noise? Open the hood, grab the throttle and twist it up and start listening and looking.
Wild Cranker
May 19, 2015 06:10 PM
Supramk3
May 11, 2015 07:55 PM
BeefMan
Sep 28, 2003 01:00 AM
