Need some advice on if i should replace the rear main seal on my civic!
hey everyone!
I just took my civic to get an Oil change and transmission flush today and the dealership informed me that my main seal was leaking. They quoted me about $1,085 to fix it. I also called up a smaller local repair shop and they quoted me $800. My civic is a 2002 LX with 156,000 miles on it. It is a great car but i don't know if i should put out that much money. Can anyone give me advice on what to do? or ways to just live with the leak? Thank you so much.
Re: Need some advice on if i should replace the rear main seal on my civic!
if thats the one between engine and trans, better go ahead and have the clutch changed if not done for a while.
any car could suffer this one... maintenance... even your body needs it.
$1000 will buy an awful lot of oil.
How bad of a leak is it?
Unless it is just a horrendous leak that pours oil out faster than you can refill the engine (you DO check your oil regularly, correct?) or it is leaving puddles on your brand new concrete garage floor, I'd ignore it until it becomes necessary to pull the transmission out for some reason.
THEN it would make economic sense to go the next step further -- after the trans is out of the way.
I bet it's only a seep, if anything. At 150K +, seeps and stains are totally expected IMO.
It is just about 5-10 drops on the floor of my garage. How long will it take to become a really big problem do you think?
5-10 drops per minute is a lot.
5-10 drops per month is not.
How rapidly does it lose oil: How often do you have to add a quart?
Has anyone cleaned the area thoroughly to see where and how the leak starts?
Could it be coming from elsewhere? Maybe runoff from an oil change?
I just started to notice it a few days ago, it is about 5-10 drops every several hours. I have not needed to refill the oil yet because i went to get it changed and they told me the seal would need to be replaced and that the oil was very low.
LionSpratt
Jan 29, 2017 11:07 PM
Blaster30
Apr 22, 2015 12:21 PM
BREADFAN
Apr 15, 2015 08:58 AM
thesushiboy
Apr 12, 2015 02:54 AM
