04 Civic Front End Noise
Old Oct 26, 2013
rvd123's Avatar
rvd123 is an unknown quantity at this point
04 Civic DX makes sort of a wobble sound, similar to the sound a washing machine makes with an unbalanced load.
Any ideas on what it could be, or what to check, kinda stumped.
If you need me to provide any more info let me know.
It's not the wheel bearings or tires or driveshaft, they have all been tested.
Old Oct 26, 2013
GolNat's Avatar
Prelude Owner
Re: 04 Civic Front End Noise
Does it make the sound all the time? Only while braking? When your going fast, slow? Does it sound like a particular side? Does the sound get louder with speed?
Old Oct 26, 2013
rvd123's Avatar
It makes the sound all the time. It doesn't matter the speed fast or slow, the sound is there. It seems more pronounced to the front passenger side, but I can hear it from both sides regardless. The sound is consistent no matter the speed.
Old Oct 28, 2013
GolNat's Avatar
Prelude Owner
I would pull the wheels off the front and check the brakes. It could be a loose caliper bolt causing your caliper to slap the rotor. The pads could be loose.
Old Oct 28, 2013
rvd123's Avatar
No it's nothing like that. Already had the front end up on jacks, with both wheels off, with the car in drive going upto 60km/h, while someone else checked both sides and went under the hood and under the car. Still trying to narrow down where exactly it's coming from.
Old Oct 28, 2013
JJ291's Avatar
No amateur/no professional
JJ291 is an unknown quantity at this point
Can you feel anything in your steering?
Old Oct 28, 2013
rvd123's Avatar
Nope, nothing.
Old Oct 28, 2013
JJ291's Avatar
Cupped tire? Have you tried swapping the tires front to back?
Old Oct 28, 2013
rvd123's Avatar
Hey listen I appreciate the replies, but you have to read my posts. The sound is there when the car is up on jacks, with no tires on.
TomSchaeffer
Nov 2, 2021 07:31 AM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
Thees1
Apr 14, 2015 08:23 AM
