Valve Cover Grommet install w/o removing VC
Hi all,
2001 Civic EX 150K 5spd
When the timing belt was done I had a new VC gasket set installed including spark plug tube seals and grommets. There is a great seal on the gasket and I don't wish to disturb that.
One of the grommets for the 10mm bolts is seeping a tiny bit of oil. Can that grommet be replaced without removing the valve cover? The grommet set from Rock Auto is only like $2.
Thank you in advance.
Supramk3
May 11, 2015 07:55 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
