Curbed wheel, what bent?
Old Oct 16, 2013
user1398's Avatar
user1398 is an unknown quantity at this point
So, I was going too fast around a turn and curbed my front drivers side wheel. The steering wheel is probably 30 degrees clockwise from where it should be, the handling is a lot worse, and I'm toe'd out now. Not sure how much toe exactly, but I measured from tread pattern to tread pattern on the front and back of the lower part of the tires from underneath the car (not jacked up), and there was roughly 3/4" difference. I know that the car was aligned pretty close to zero beforehand. Took off the wheels and checked the LCA and tie rods for any abnormal bends. I tested for abnormal play in the tie rods and hub of the wheel, and I didn't see any. So, does anyone have any ideas what could have bent? And should I try to find and replace it or just readjust the toe to zero?
Old Oct 16, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: Curbed wheel, what bent?
Probably lower control arm. If hit VERY hard it could be a knuckle. Always replace compromised parts. Impossible to tell without looking at it but usually first thing is the LCA.
Old Oct 16, 2013
user1398's Avatar
Ok, I'll take some measurements of the LCA and compare it to the other side. I don't think I hit it very hard. Thanks for the response, I appreciate the advice.
Old Oct 18, 2013
check the prices, they are not too pricey
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
BryanM.
Aug 29, 2015 03:26 PM
tuvok
Aug 28, 2015 10:04 AM
Strycker
Aug 18, 2015 02:25 PM
brainwashedmc
Jul 27, 2015 10:05 PM
