Does this sound like a bad torque converter?
Old Aug 28, 2015
BryanM.'s Avatar
BryanM. is an unknown quantity at this point
2007 EX. Car shudders a bit when driven for several miles, usually only after sitting overnight, but sometimes out of the blue when it has been driven all day. Feels very similar to a out of balance wheel or a bent rim. Does not seem to matter which gear it's in, or when TC locks/unlocks (OD). Happens around 45-60 mph or so. Smooth as can be on the highway 75+ mph.
The alloy wheels have been checked for straightness 3 times at 3 shops, 3 different sets of tires, and 2 alignments. I'm pretty confident it's not wheel related lol
The shudder comes and goes. Usually after it warms up it's fine, but might pop up later on.
Not to experienced with automatics, this is my first one. Any ideas?
Old Aug 28, 2015
mikey1's Avatar
Re: Does this sound like a bad torque converter?
does it sound like what?
i can't hear anything from here
Old Aug 28, 2015
Yes they can and do have TCC shudder, cars that have had transmission services neglected or wrong fluids used are the ones that seem to get really bad about it. HINT lol
Since the trans can engage the converter clutch in all gears, you may feel it happen at nearly any speed. Sometimes they will shake at 20 while going slow, sometimes immediately after shifting gears, sometimes higher speeds. The shake can shake the entire car at times.
Shakes like a dog pooping broken glass.
Once it starts acting up, try putting the shifter in D3 and driving around, see if the shudder disappears.
If I suspected TCC shudder, I'd first want to verify and prove it on my scanner.
Then if proven, the next suggested step would be to change the trans fluid 3 or 4 times (official procedures) using genuine Honda ATF DW-1 fluid.
If that does not take care of it, then you may be looking at replacing the torque converter.
Old Aug 29, 2015
BryanM.'s Avatar
Thanks for posting. I did a 3x drain and fill and it did nothing. I kinda doubt a 4th time will do anything.
Can I use a regular scan tool to diagnose this?
Also, I've had the car for 1.5 years, the shudder doesn't SEEM to be getting worse. What is the worst damage that this shudder could cause? Is it tough on the trans?
Old Aug 29, 2015
If 3 made no difference, I wouldn't expect a 4th to change anything either.
Kinda doubt it unless you have a high end scanner or factory equivalent scanner.
I test drive and record engine RPM, input shaft RPM, and a few other items, then graph out the recording to view. Overlay and zoom on the two RPM graphs and look for RPM differences when the two values should have been exactly the same (@TCC 100% applied).
Then decide if what was felt is really coming from the torque converter clutch.
One RPM line kinda looks like teeth on a saw blade when the shudder is captured.
Much newer cars may have a PID for TCC slip ratio, that makes it a bit easier.
Depends on if what you feel is really coming from the trans/TCC.
Maybe you have a collapsed motor mount (a common failure) causing vibration or something.
I've seen some of these cars with the TCC shudder condition and apparently the people either ignore it or don't understand it's a problem.
I can't tell you if it will seriously damage the trans, but I imagine it isn't helpful.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
jbradley4809
Apr 7, 2017 04:23 AM
docmartin14
Jul 30, 2015 11:26 AM
Fastfebur
Apr 26, 2015 11:57 PM
silvervtec01
Dec 9, 2001 08:50 PM
