01 EX oil leak
Old Nov 27, 2013
presta24's Avatar
presta24 is an unknown quantity at this point
01 EX oil leak
Looking at buying my bro in laws 01 ex. it has 147k on it. Im thinking the oil leak is most likely cam/crank seals. The TB/WP hasnt been done yet. If I buy it thats the first thing I will do. Is there typically anything that leaks oil on these around that mileage? This is my first civic. Also has a PS leak. I think it coming from the feed line on the bottom of the resevoir.
Thanks id advance for your help guys!!
Old Nov 27, 2013
CraigW's Avatar
Re: 01 EX oil leak
Originally Posted by presta24
it has 147k on it. The TB/WP hasnt been done yet.
Old Nov 27, 2013
presta24's Avatar
Re: 01 EX oil leak
Originally Posted by CraigW
My thoughts exaclty
Old Nov 27, 2013
presta24's Avatar
Re: 01 EX oil leak
whats interval for TB? 90k or 100k?
Old Nov 27, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: 01 EX oil leak
100K or seven years.
Old Nov 27, 2013
Re: 01 EX oil leak
Doesn't the manual say 80k? Most people do replace it at about 100k though.
Old Nov 27, 2013
Matt_75's Avatar
Re: 01 EX oil leak
Actually I just looked again and it says 110K or 7 years. It also says this on another page.
Timing Belt
The timing belt should normally be
replaced at the intervals shown in
the maintenance schedule.
Replace this belt at 60,000 miles (U.S.)
or 100,000 km (Canada) if you
regularly drive your car in one or
more of these conditions:
In very high temperatures
(over 110°F, 43°C).
In very low temperatures
(under 20°F, 29°C).
Old Nov 28, 2013
JJ291's Avatar
No amateur/no professional
JJ291 is an unknown quantity at this point
Re: 01 EX oil leak
Presta24. One piece of advice that I learned the hard way. Need to watch for a little seal in the oil pump as well. It is a known suspect to leak and bleed out through the lower timing cover. I would be looking for the following for potential leak path:
Cam Seal
Little plastic cover on the other side of the camshaft
Front/Rear Seals
Oil pan gasket
Little o-ring in the oil pump
Oil filter/pressure sensor
If you do the TB/WP it is a very convenient time to do the little o-ring on the oil pump because all you have to do is pull the pan and the pickup. If you do the TB/WP I would also recommend making sure a local dealer has the lower and upper covers available if you need them - they have these stupid little metal on plastic screws that tend to break and spin out - especially on old covers.
Just a few recommendations - good luck.
LionSpratt
Jan 29, 2017 11:07 PM
RIPSAW
Nov 6, 2015 04:36 AM
Kyrian
Jun 26, 2015 11:48 AM
671civicLX
Jun 13, 2015 05:56 PM
davidpaustin
May 20, 2015 12:59 PM
